Old 05-23-2013, 11:32 PM   #1
ScottH
ScottH's Avatar
Question What do I need to convert from 6 cyl to 8?
Will be getting a 83 swb in the near future that was originally a 250 6 cyl engine.
I plan to put a sbc in and was wondering what is needed to make the change?
Can I use the engine mounts from the 6? Do they need to be relocated?
I am thinking about using the original sm465 trans & would like to keep in the 6 position (trans, cross member, etc.).
Any info is appreciated.
Thanks guys!
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 05-23-2013, 11:40 PM   #2
izzy_Britton
izzy_Britton's Avatar
Re: What do I need to convert from 6 cyl to 8?
It has been forever since I done a conversion, so dont quote me on it.
But i believe you NEED the SBC motor mounts and they bolt to the same spot as the 6ers do. I think all the rest of the hard parts bolt up. you will need some fuel lines and radiator and heater lines and what not but otherwise you should be good to go.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-24-2013, 10:55 AM   #3
ScottH
ScottH's Avatar
Thanks Izzy
Any other input, suggestions, etc??
Old 05-24-2013, 11:45 AM   #4
chrismoore701
chrismoore701's Avatar
I recall the same for my swap
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-24-2013, 01:25 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My truck (78 model half ton) was different. The engine mounts were dual drilled from the factory for inline 6 or V8 options. GM even labeled them for knuckledraggers like myself so we wouldn't be confused.
Tx Firefighter is offline   Reply With Quote
Old 05-24-2013, 04:04 PM   #6
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
I agree you should be able to use the same engine mounts, you should be buying new clam shells anyway. Your trans & bell housing should bolt right up. But if I remember correctly you will need a V8 flywheel and clutch. you will need a V8 radiator and wire harness though.
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 05-24-2013, 04:33 PM   #7
Tx Firefighter
If the current six cylinder is a 4.1L (250 cu/in), the flywheel and clutch and starter will bolt directly to any non 400cid small block engine that uses a 2 piece rear main seal.
Old 05-24-2013, 10:41 PM   #8
ScottH
ScottH's Avatar
thanks guys, appreciate the info
