![]() Join Date: Mar 2010
undercoat ideas
Just finished blasting all the crap off underneath my 65. Wanting to know everyones ideas/thoughts on undercoating/rustproofing/paint???
Keep in mind I want the benefits of sound deadening as well. Thanks in advance.
65 burb On the road Mar 26th Finally |
![]() Join Date: Oct 2012
Re: undercoat ideas
For a frame off job...POR 15 products/coatings under...sound & Heat deadener matting in cab and doors.
![]() Join Date: Mar 2012
Re: undercoat ideas
I'm planning on using lizard skin coating. There's a few builds on here using this product and looks great and will do what you're looking for. They also offer a ceramic heat resistant coating. Check it out.
![]() http://www.lizardskin.com/sound-control-insulation.html Posted via Mobile Device
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
Re: undercoat ideas
I planned on putting bedliner on all of my undersides after shooting it with DP90. Anything that can get hit with a rock is getting bedliner on it.
Disclaimer: I'm no pro and this is just info I've gotten from other builds.
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! ![]() Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
Re: undercoat ideas
Ive used this stuff called stutz or something. its like a bed liner and is applied with their gun.sprays out nice.then I used dynamat on the inside.
Re: undercoat ideas
I like epoxy primer. Good protection in shaded applications. Easy to repair.
I hate removing bed liner and thick under coat. |
#7 | |
Re: undercoat ideas
Re: undercoat ideas
Your right, no sound protection.
Re: undercoat ideas
Definately bedliner. I had a friend who used to own one of these shops, and had him do the underside of my hood, and the gas tank on my old 65 Chevy II. He used the "leftovers" from different jobs, called "slag". It all comes out black so it should work for your truck(s), and it was cheap.
![]() Join Date: Sep 2011
Re: undercoat ideas
Rhino lining for me.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Senior Enthusiast
Re: undercoat ideas
From my experience U-Pol Raptor bedliner obsoletes everything else. It is comparitively inexpensive, easy to apply, and extremely durable.
http://67-72chevytrucks.com/vboard/s...d.php?t=581389
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Re: undercoat ideas
x2 on the lizard skin. I plan on using both the lizard skin ceramic coating and sound deadening.
It's Better With Nitro
Re: undercoat ideas
I used the 3M Body Schutz this time around on the underside of my cab and inner fenders. It's the third time I've used it (previous two times were customer requests on the backsides of various panels I fabricated), and it is really easy to work with and use.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Re: undercoat ideas
Epoxy first, then add undercoating/sound deadener. I like Lizzard Skin. You can also mix up a batch of cavity wax and spray around all the seams and inner channels for extra rust protection.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#15 |
Re: undercoat ideas
I am using SEM rust shield on my 66 k10.
