Old 05-25-2013, 05:29 PM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
Issues
Alright my swap is done but I'm having a few problems that I was hoping someone on here could help me out with. When she idles she runs good. But when I'm driving she has a few times that she skips or misses. Also when I start it I have to feather the gas like its still carbed. Also when I pull up to a light and leave it in drive it lurches, but if I put it back in neutral it idles smooth. If anyone's knows what could be causing these problems pleases let me know.
Brandon
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 05-25-2013, 05:31 PM   #2
smoky02
Re: Issues
Mods please move to the LS swap section
Old 05-26-2013, 01:41 AM   #3
vannatta20
vannatta20's Avatar
Re: Issues
Best bet would be to get a scan tool and see what's going on.
vannatta20 is offline   Reply With Quote
Old 05-26-2013, 02:13 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Issues
See if its throwing a code, and which one. If its actually misfiring and stumbling, you've got things like the plugs, wires and coils to look at. Things like a dirty or stuck injector can cause bucking and stumbling as well.
When the engines' in neutral, there isn't any load on it so those problems might not be as obvious over the regular shakes and noises of a cammed ls.
Also things like a vacuum leak, issue with the tune, improperly hooked up brake switch causing issues with the trans etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-26-2013, 11:44 AM   #5
smoky02
Re: Issues
The only code I'm throwing is p0101. And it's not consistent that makes me think it's not in the ignition system.
Old 05-26-2013, 10:42 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
Re: Issues
That's a MAF trouble code, assuming your ECM is still MAF based it could be throwing off your tune in all kinds of ways. Where did you put the MAF in relation to the throttle body? Also, is it new or old (did it come with a salvaged motor?)
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-26-2013, 02:03 PM   #7
vannatta20
vannatta20's Avatar
Re: Issues
Check your fuel pressure and spark plugs
Old 05-26-2013, 04:48 PM   #8
smoky02
Re: Issues
What should my fuel pressure be at?
Old 05-26-2013, 06:17 PM   #9
vannatta20
vannatta20's Avatar
Re: Issues
In the 50'S psi range.
Old 05-27-2013, 07:30 PM   #10
smoky02
Re: Issues
The MAF is new from the parts store. And it's run at the end of my cold air intake.
Old 05-27-2013, 08:35 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
Re: Issues
Well all that sounds fine. I would look and make sure the wires aren't cut or rubbed by accident, maybe chafed on something? Also it's possible you over oiled your air filter element and some of it made its way onto the MAF. I doubt that would cause your symptoms, but it would throw the code. A bad MAF wire somewhere could be causing your issues however.
Old 05-28-2013, 11:52 AM   #12
vannatta20
vannatta20's Avatar
Re: Issues
I had that code as well. I just cleared it and it hasn't came back. I've ran it a few times without the maf connected testing things. Clear the code and keep checking the basics.
