Bump stops
So what do you guys with bump stops? upper and lower ones, stock arms.
any pics?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Bump stops
Keep the upper.
Remove the lower.
Re: Bump stops
Should i just remove the actual bumpstop or should i also cut that whole raised part out of the control arm that the bumpstop mounts to?
#4 | |
Re: Bump stops
I remove the part that holds the lower bumpstop,... but leave a little to use as a steering stop for the spindle.
Re: Bump stops
Ohhhhh alright guess i'll just see what I have to do as I go. Thanks for the info man, i'd +rep you if this forum used it.
Kill Bill...et
Re: Bump stops
Agreed. I cut everything flush except about a one inch "L" off the steering stop. I'm running 15" rims so I had to trim the lip off my A arm too. Left the top A arm stock.
