67 C30 rear drum removal ?
Ok being new to this how does the rear brake drum come off so I can check shoes and replace wheel cyls? Maybe this is basic but new to me...sorry. Does that cap thing with the 6 bolts need to come off? thanks
Re: 67 C30 rear drum removal ?
Big learning curve ahead of you.
First thing to do is download the service manuals if you don't have them. Then read up on the brake and axle sections. http://67-72chevytrucks.com/vboard/s...d.php?t=558016 You are right in that the axle shaft does need to come out of the housing then the outer axle bearings. This allows the hub/brake drum assembly to be slid off the housing. The parts are heavy and the axle bearing lock nut is torqued to 175 lb-ft. The hub oil seal is easily damaged during servicing too. It would be best to have some help the first time through.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-28-2013 at 03:51 PM. Reason: add image |
#3 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks guys for the info and picture and link. It will help greatly! Is (are) there any special tools needed?
It takes a special socket to get the lock nuts off and back on. You can get it at most parts stores.
69 Chevy 4x4 383 Power ![]() |
