Old 05-28-2013, 11:22 PM   #1
jcd9730
jcd9730's Avatar
Ran out of gas...
I think the pump is burnt out maybe? Is that possible? I ran out of gas, after filling back up, when I try and start it, it just spins, and is really hard to start. If it does start it will not idle. As soon as I let off the gas it just sputters and will die
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 05-28-2013, 11:26 PM   #2
mud.man.rj
mud.man.rj's Avatar
Re: Ran out of gas...
Only way to know is do a fuel pressure test, have had a simular experiance and turned out to be the ignition module, that is why you want to check for fuel.
mud.man.rj is offline   Reply With Quote
Old 05-28-2013, 11:31 PM   #3
jcd9730
jcd9730's Avatar
Well, it's got fuel. Gas sprays when I hit the pedal. If I pump it a bunch, it will start, but always dies after a minute when I let off
Josh
Old 05-28-2013, 11:37 PM   #4
Mint68
Mint68's Avatar
If it is hei and you want to test the ignition module, regular auto parts stores can test them. I had a bad one that would run till it heated up, then die and not start till it cooled off. Other ones I've had go bad will just turn over and never fire.
Mint68 is offline   Reply With Quote
Old 05-28-2013, 11:41 PM   #5
jcd9730
jcd9730's Avatar
It ran fine before I ran out of gas. Problem is, I ran out just as I pulled into the station. Meaning I'm still sittin here....
Josh
Old 05-29-2013, 09:43 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by jcd9730 View Post
......... Problem is, I ran out just as I pulled into the station. Meaning I'm still sittin here....
"Mobile Device." Great life savers. Young guys need to thank all the older guys they see just in case one of them was involved in the invention of these new devices.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-30-2013, 12:19 AM   #7
mud.man.rj
mud.man.rj's Avatar
Well she is up and running so that is all that matters.
Old 05-28-2013, 11:56 PM   #8
Scott>72-GMC
Scott>72-GMC's Avatar
Sometimes when u run that low it knocks some sediment loose. Check fuel filter?
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 05-29-2013, 12:25 AM   #9
mud.man.rj
mud.man.rj's Avatar
That is what I was thinking also, could be fuel filter is partly plugged, for what it is worth change it then if still not enough check fuel presure, it may be low and supply enough to start only then not be strong enough to keep the supply up to demand.
Old 05-29-2013, 12:39 AM   #10
jcd9730
jcd9730's Avatar
I just let it sit for awhile, started it and held my foot on the gas enough to keep it steady for about 10 minutes. Ran fine after that. Maybe something did get caught, but its a new tank, filter, everything. Strange
Josh
Old 05-29-2013, 12:55 AM   #11
bugmasta
bugmasta's Avatar
Sounds like a vapor lock to me. Pretty common if you run the lines dry and the motor is hot.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 05-29-2013, 01:04 AM   #12
jcd9730
jcd9730's Avatar
How does that cause vapor lock? I thought vapor lock was when the gas got so hot it vaporized?
Josh
Old 05-29-2013, 08:02 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
What are you running for a carb?
LockDoc
Leon
Old 05-29-2013, 09:07 AM   #14
CC69Rat
CC69Rat's Avatar
LockDoc
My guess would be Edelbrock 1406/1407 (?) I had one to do almost the exact same thing.. but mine wouldn't start back up at all.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-29-2013, 08:05 AM   #15
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
When it runs out of gas and the engine is hot from running,you get almost instant vapor lock.Not much fuel in the lines so the heat vaporizes the fuel quickly.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-31-2013, 12:36 AM   #16
bugmasta
bugmasta's Avatar
This.
Old 05-31-2013, 05:26 AM   #17
Tuff Gong
Tuff Gong's Avatar
A little off topic, but when I was a lot younger, I own a 71 Cheyenne. The fuel gauge was broken and I can't even count the number of times I ran out of gas! Beer was way more important to me at the time, so I never filled her up completely. I use to swerve from side to side just to hear the gas sloth back and forth. I would also stand outside the truck and shake it too see if I could hear any gas. Obviously it didn't work to will. Lol. Glad to hear your truck is back up and running.
Tuff Gong is offline   Reply With Quote
