Could my tranny be causing a loss of power?
Hello, 83 gmc short box. 350ci backed by 350 tranny with 2500 stall.
This truck is about to drive me crazy, I have no take off power, It seems like I have a 4 cyclinder underneat the hood, its that bad. High revs before it will finally shift into second. Weird experience here lately has been when im crusining @ 60 mph the truck will all of a sudden start reving really high and seems like someone has put the truck into nutral. So, I even tried putting into first gear at the bottom so i know for sure it would be the right gear to take off in and it seems to help once in awhile, or not at all. Im thinking that Im either about to replace the torque converter or i may be losing the tranny in it. Thanks for all help upfront guys!!! |
Re: Could my tranny be causing a loss of power?
With a stall that high unless your engine has a pretty radical cam in it that is probably your problem right there. Without more info on your engine it's hard to give advice on what stall you should be running.
Im seriously thinking that its only a stock 350 bc the stall that is in it is kinda retarded imo and doesnt suite my needs. I just bought the truck like that. Im also thinking that im starting to lose 3rd gear. BUT, lets say its a stock 350, what then should I do?
#4 | |
2500 is not high at all, thats just over stock . i'd be looking into your transmission, something doesnt seem right
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Should go from the back behind the carb and run down the passenger side to the back of the trans at the rear of the pan.
You could have internal leaks on the seals and prong inside that comes with higher mileage transmissions. So it could be slipping in an out of gear as your driving. 2500stall is high but not overkill. High stalls also create a lot of heat. Possible that your trans is cooking itself Take out your dipstick and smell it. It smell burnt or fishy? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#8 | |
Posted via Mobile Device |
What is the purpose of the shifting module?
It is a device that senses the manifold vacuum to determine when the transmission needs to shift. At idle you most likely have15-20 inch of vacuum. As you increase the throttle and load the vacuum decreases.
Less vacuum= higher shift rpm more vacuum= lower shift rpm |
#11 | |
Pump may be going out as well. You shouldn't be getting more than a warm floor from the trans. If its hot then the tans has to have something wrong
sounds to me like its not starting in first, and a 2500 stall is very small!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
#15 |
trans pump, behind the torque converter
