Old 05-30-2013, 10:01 AM   #1
ezstriper
ezstriper's Avatar
72 A/C vacuum line diagram
Just ended up with a very nice 72 w/factory A/C unit works but there is no vacuum lines running to the inside at all..the canister is on the case...I can see a vacuum motor on the pass side with nothing going to it...so hoping somebody has a diagram for one of these...thanks Rob
ezstriper is offline   Reply With Quote
Old 05-30-2013, 10:37 AM   #2
KEL
72 GMC
KEL's Avatar
Re: 72 A/C vacuum line diagram
Here ya go
KEL is offline   Reply With Quote
Old 05-30-2013, 10:48 AM   #3
ezstriper
ezstriper's Avatar
thanks !!!!
Old 05-30-2013, 10:59 AM   #4
KEL
72 GMC
KEL's Avatar
my pleasure
Old 05-30-2013, 02:05 PM   #5
SS Tim
SS Tim's Avatar
Welcome to the board!
Here is a link where you can download the service manuals. They have a lot of A/C information.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 05-30-2013, 03:39 PM   #6
ezstriper
ezstriper's Avatar
thanks...have to figure out what I have...the A/C compressor' lines, dryer, not factory, evaporator case ??? inside was original A/C truck...all that appears correct, do no see the outside air door diaphragm at all...the RIC diaphragm is there..controls are correct I believe...thanks again for all the help ! Rob
Old 05-30-2013, 04:24 PM   #7
KEL
72 GMC
KEL's Avatar
Sorry
Didn't even notice you were new
Welcome !
Old 05-30-2013, 06:00 PM   #8
ezstriper
ezstriper's Avatar
Oh...no problem...been on many sites regularly....just found this after getting this truck...anybody know where the outside air door diaphragm is supposed to be ?? thanks !
Old 05-30-2013, 06:42 PM   #9
SS Tim
SS Tim's Avatar
Here they are...
Old 05-30-2013, 08:05 PM   #10
tommys72
tommys72's Avatar
Not to jack the thread, but what controls the pass. side inside air vent, mine quit working on me
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-30-2013, 09:04 PM   #11
SS Tim
SS Tim's Avatar
Take a look at the vacuum map in post #2. The control head switch controls the vacuum to all the vacuum motors and the coolant valve. If the recirculation vacuum motor is not working, I'd check it first with a hand vacuum pump and work backward from there. You need to be reading the service manual to diagnose this vs throwing parts at it. Could be the motor, switch, hoses, or source vacuum.
Old 09-27-2017, 11:05 AM   #12
lugnuts09
Is there a kit for the vacuum hoses? If so do you know where i can get it? I'm restoring a 1969 c20
lugnuts09 is offline   Reply With Quote
Old 09-27-2017, 12:09 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 A/C vacuum line diagram
I've never seen a kit.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
