06-01-2013, 05:48 PM | #1 |
go cyclones
Panel alignment issues
So i found that my radiator mounts were never reallynpresent. Today and replaced them with some new ones. I think i opened up a can of worms. As soon as i got the new mounts in the gap between my doors at the top closed up. I tried tlooseningnup all the bolts but that made it worse. I knew that there was goingnto be some movement because i was going add about 1/4" to the front. But it moved alot. It he pictures are the before mounts and before and after of the gap.
The easy solution would be to cut the rubber mount in half. How thick is it suppose to be? Other than that iam i going to have to take the entire thing apart to realighn? |
06-01-2013, 05:53 PM | #2 |
go cyclones
Re: Panel alignment issues
Here is the now picture. The quarter is hitting the door. As as i can tell the door is correctly alaiogned.
06-01-2013, 06:05 PM | #3 |
something u would probably do if it was trying the same thing. I woul but new cab bushings along with the core supports. That way your starting from a level playing field. It would be hard to replace one and not the other and get everything straight.
Posted via Mobile Device |
06-01-2013, 06:10 PM | #4 |
Cluster King
Even if the cab mounts are in good shape or new, you may have to shim them. The cab mounts have to be in the same line as the core support or you are going to have panel alignment issues.
06-01-2013, 06:17 PM | #5 |
go cyclones
About five years ago i did a frame off on the truck. I did eveything but the body work. I heard a knocking sound a few times and finally tracked down to the "missing" radiator mounts. I thought the guys that did the body work did a decent job st the time, but now that i have had some more time to start to finish the last 10% im finding lots of problems.
Is it uncomon to shim a body mount 1/4"? |
06-01-2013, 06:26 PM | #6 |
Cluster King
I would not worry about 1/4 inch of shim if needed. You are working on a Blazer?
Just remember that what you do will have effect on other things. How do your doors shut now? It is all related and it will take time to get correct. Sometimes you will have to add shims to the body/cab to get the doors to shut correctly or add to the radiator support mounts. If the doors shut nice and you are happy with the gaps, then you may need to shim everything 1/4 inch and then align front sheet metal to match. |
06-01-2013, 06:28 PM | #7 |
go cyclones
The doors are fine. I am going to go look at the mounts and look at whats what.
06-01-2013, 06:54 PM | #8 |
go cyclones
Ok the four middle body mounts have about 1/4"-3/8" of shim. The four outside mounts have nothing. Are these the correct modt miunts?
06-01-2013, 06:55 PM | #9 |
go cyclones
Outside mounts
06-01-2013, 10:58 PM | #10 |
Um...thats not what i just replaced my rad support and cab bushings with.....but all my stuff lined up plu or minus an 1/8th of an inch of moving and or shiming...
06-01-2013, 10:58 PM | #11 |
But maybe someone else will knoww for sure!!
06-02-2013, 12:58 AM | #12 | ||
"I ain't nobody, dork."
Those cab mounts look weird. They are squashed way too much for cab mounts.
These trucks had crappy panel alignment from the factory... so getting them to line up 40 years later can be a real headache. Gary
06-02-2013, 06:56 PM | #13 |
go cyclones
Alright today i loosened the body mounts and jacked up the body until the panels where alaigned. Its going to tar about 3/16" and it will be good. Ordered some shims and should be good to go be next weekend.
Last edited by JayDubBlazer; 06-02-2013 at 06:59 PM. Reason: Cant type on the ipad |
