S10 V8 swap motor mounts
So I bought this S10 frame from a guy who had already had it down to a rolling chassis with hopes to turn a 51 ford into a rat rod.
This left me wondering what engine used to be in this truck. The reason I'm asking is for V8 motor mounts. I've been researching them, but they ask if the truck was 4 or 6 cylinder, and 2wd or 4wd. The frame I have is a 2wd, but as for engine, I have no clue. Does anyone know by looking at the mounting holes which "Jegs" motor mounts I need to order for a short block chev? |
Re: S10 V8 swap motor mounts
Let me see if I have any pics I may be able to help you I have had 4 V8 s-10s
2.8 and 4.3 both use the same holes and mounts as they were both v6 take the top hole and the two outer bottom ones
Ok thanks
Posted via Mobile Device |
and a few others
Before you order motor mounts, what are your plans for this frame?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Old Heap Driver
Don't use S-10 V8 mounts! You need to set the body on the chassis, then mock up the motor location. Plan on building motor mount stands from scratch.
In a V8 S-10 the motor needs to be located as forward as possible, in an AD truck you need the motor more rearward in the chassis. I have both a V-8 S-10 and an S-10 chassis under my 50, the S-10 mounts were worthless in the 50.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
#8 | |
So you're saying these mounts won't work for my application? Ummm....damn!:hmm Posted via Mobile Device |
and a few others
Actually there a couple guys on here (including me) who have used them. But you have to reverse them. Left side on Right, Right on Left. And they have to be supported in the rear because they hang over. But, I wouldn't go out and buy S-10 mounts. I, and I assume the other guys here who have used them just happened to have them already. Also, in my case I had to go with electric fuel pump as you can see....
I built my own S10 V8 mounts using 63 Chevy pickup mounts which are about 1" tall and a plate welded to the stock mount. It seemed a lot easier and it sure was cheaper! Can get pics if interested (the mounts are still around here).
Sorry I dont have any pics that show the mounts
Alrighty, well I'm yanking the 400 out tomorrow, so I should have more of an idea as to where and how. I'm a total hot rod virgin, so be gentle and patient with my ignorance lol
