NP 205 Help me...
I'm putting new gaskets in my 205 while I've got it out for a clutch swap. All was good until I took off the rear output and the 15 needle bearings inside the output shaft got out. Is it just a matter of being patient and sticking them back with vasoline? The washer and snap ring that keep them there make it tough for a guy with fat fingers. If not is there another trick I can't find? It doesn't look like there is any access except from the front...
I need this back together ASAP. Any help is appreciated. Posted via Mobile Device |
![]() Join Date: Aug 2008
Re: NP 205 Help me...
I don't think there is any other way!
Have fun! Posted via Mobile Device
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
![]() Join Date: May 2003
Yup, some thick grease to hold them in place, use something skinny to put them into place ( Not your sausage fingers ) "LOL"
![]() You can stick them to a screw drive with the grease and carefuly get the in place ! Good Luck ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Grease Monkey
Use a popsicle stick with heavy grease. If the 205 is out of the truck you'll want to put the tcase on its back, but in a way that you can still get to the rear output side. This will allow you to CAREFULLY slip the rear output shaft back on in with it face up. If you tip it to far to either side the bearings will fall out of place. I just did this over Memorial weekend. Let us know if you have any more questions. GOOD LUCK!
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
