Old 06-03-2013, 01:33 AM   #1
jhyder408
12 bolt rear question
so I bought this '67 long bed c10 for the bed and front clip. I am parting out the rest. I looked at the glove box door and the data plate said
posi-trac 4:11r. I jacked up the rear, marked the tire and marked the pinion. turned the tire one full revolution and the pinion spun a little past 4 turns. I inspected it, looks like it has never been out of the truck. I posted it on craigslist and had it sold in a bout a week. I went and pulled it out, which was a pain by the way, my theories of it never being out was correct by the way the u bolts being such a pain. Now to the point, the guy that bought it said when he got it home and checked it, said it was a 3:73 posi not 4:11.
This has been bothering me, I am not a scammer especially when selling parts. And I just think he is wrong.
SO, anybody have any thoughts on the matter???
'68 C10 Step Side, 250 6cyl, converted long to short, work in progress
jhyder408 is offline   Reply With Quote
Old 06-03-2013, 05:45 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 12 bolt rear question
If you want to change the [GL-5] 90wt gear oil anyway, pull the pumpkin cover off the back of the diff and count teeth.
I think maybe the rearend was changed at some time anyway. I doubt if any one could tell an 18-year old differential job from a 40 year old one, given enough time, road muck and corrosion. If the nuts on the U-bolts are torqued correctly 120 foot-pounds -- they would be a bear to get off, anyway. Changing a rearend from 4.11 to 3.73 would be something a PO might do for better mileage.
Is it still a Posi? A lot of Posi rears get cannibalized for other projects, and if they blow up they are more expensive to replace or rebuild. Also the glovebox door with a SPID from a different truck may have found itself bolted onto the project at some point.
Or a PO used to a higher geared vehicle like a 3:08, might guess wrong about a lower-geared differential, without trying to be a liar.
Old 06-03-2013, 06:21 AM   #3
cdowns
cdowns's Avatar
really both of your faults but mostly yours for takin responsibility for not checking to remove any doubt as to what u were selling
just guessin and hopeing aint really a good sales practice
me i would not have bought it without lookin cause i do not trust
