06-03-2013, 03:36 PM | #1 |
Having issues 99 Burban k1500.... Help.....
99 Burban 4x4 k1500 LS model anyhow weak on take offs gets ok when hits 2nd gear, runs good after that, same loss of power no balls when hitting kick down too... Engine light comes on at that point P0101 and P0101pd.. Cleaned the mass airflow sensor, ran it same issues with no balls on take offs, pass downs and climbing a small hill like an on ramp to a freeway incline.... Any ideas, help getting really frustrated.... Thanks. Sevend2!!!!
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
06-15-2013, 10:55 PM | #2 |
Re: Having issues 99 Burban k1500.... Help.....
How's the fuel pressure? 60 psi is the spec and down below 55 can be noticeable. If the miles are high, check the distributor gear for wear. These are roller cam engines and the cam gear is harder than the dist gear. When the mileage gets in the 150k range is when this can become an issue, usually when pulling hills.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
06-17-2013, 12:53 PM | #3 | |
Thank a Veteran. They have sacrificed more than you will ever know! 2003 Chevy Z71 Tahoe 190,500 miles 2002 Chevy Silverado 1500 4x4 230,000 miles 1987 custom built Silverado 4x4 435,764 miles 1985 K5 Blazer 396 bb 4x4 project 1982 K5 Blazer Silverado 4x4 519,348 miles |
06-17-2013, 01:24 PM | #4 |
I'd run vacuum gauge tests.
I'd pull plugs and inspect color. I'd do bwood fuel psi test but won't let you know if spider legs leaking. bigsteve97 is looking at a prime suspect w/ a long rap sheet. As always may be multiple gremlins. This is my plugs on bad spider: |
06-17-2013, 01:34 PM | #5 |
If your spider is bad I'd consider the newer species available at at a parts store near you.
Astute observers will note proprietary heater hose delete |
06-17-2013, 05:22 PM | #6 |
Well, when was the last time a complete tune up was done? Cap, rotor, wires, plugs, fuel filter, air filter?
Thank a Veteran. They have sacrificed more than you will ever know! 2003 Chevy Z71 Tahoe 190,500 miles 2002 Chevy Silverado 1500 4x4 230,000 miles 1987 custom built Silverado 4x4 435,764 miles 1985 K5 Blazer 396 bb 4x4 project 1982 K5 Blazer Silverado 4x4 519,348 miles Last edited by biggsteve97; 06-17-2013 at 05:28 PM. |
06-17-2013, 06:07 PM | #7 |
I'd investigate possible causes of P0101; MAF, EGR, etc.
It would be nice to have a high end scan tool that can measure timing, sensor data, etc. Too bad they tend to cost over $300. |
06-21-2013, 07:20 PM | #8 |
engine rebuilt a couple of years ago, just changed out fuel pump, seems better, had it smoged, passed, but had warning for mass air flow sensor, I have one on order, going to change it out when it gets here. thanks for all the info, and directions to look and go.... will keep posted!!!
07-09-2013, 11:17 AM | #9 |
new fuel pump, fuel filter, dist cap and rotor, new plug wires and plugs, new MAS, new air filter...
problem seems only after I drive it for a while and stop, like 5- 10 miles then turn it off, it don't want to start up again.. takes a while to crank over... some rare times sitting at a stop sign the RPMs will flutter around the 300 - 500 range, Normal rpm is 600-800...... I am not mechanicly inclined with , tend to know a little bit more about our old 60s and early 70s one... grrrrrrrr
07-09-2013, 12:25 PM | #10 | |
I would pull the ignition control module from the bracket next to the ignition coil and have it tested. Seen those alot lately being bad.
