06-03-2013, 07:46 PM | #1 |
Injector questions...
I've come down to firing my 4.8 swap. At first I couldn't get it to start at all. Pulled injectors and they were fullllll of bad gas turned goop or whatever you want to call it. I "cleaned" them (kerosene soak, carb cleaner, boiled in water for 5 minutes) and it worked (for a little bit). After cleaning them it'll start up with a lot of cranking and idle for 3 minutes or so and then just shuts off. I revved it in that time too and it sounded perfect. Then it just dies. It basically will not start for like 10 minutes but if I give it time then it'll pop right off again and run for a while.
Soooo; here is the question: if I get new injectors could I possibly experience the same thing? I'm running a return system with a factory 01 Silverado fuel filter and an external walbro pump with the factory tank. Where else should I look. I don't want to drop a whole lot of money for new injectors and then I'm back to square 1 after running it for a little. Any help appreciated guys! Gotta thank you all for getting me this far! Before my C10 and the lsx swap, as far as I went with vehicle maintenance was brakes and oil changes. Learning a lot...
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
06-03-2013, 10:52 PM | #2 |
Addicted to Rust
Re: Injector questions...
I bought a set of takeoffs from eBay. Be aware that there are harness differences, and the injectors have different lb/hr ratings so the tune may need tweaking. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
06-04-2013, 04:59 AM | #3 |
I plan to get the same part number injectors so I would think that wouldn't be an issue!?
06-04-2013, 10:32 AM | #4 |
could be trash in the fuel rails or the lines. How new are the tank and lines? Were the fuel rails and injectors new or used? Try doing a seafoam treatment through the fuel system. It will clean the junk out of the fuel injection system.
66 SWB Stepside: Project C-O6 06 ZO6 MSM 6spd 562/520rw N/A 06 Caddy CTS The Daily 07 Hayabusa - absolute chaos |
06-04-2013, 02:09 PM | #5 |
Tank is original but the truck has been driven ever since it was new. Lines are new. Rails came with the engine. I'll try the seafoam
06-04-2013, 02:40 PM | #6 |
Did you have the VATS programmed out?
1972 Blazer body...need to get a thread started for the rest of the story |
06-04-2013, 04:41 PM | #7 |
[QUOTE=NPilot1975;6107121]Did you have the VATS programmed out?
Posted via Mobile Device[/QUOTE Yes, it runs for like 5 minutes perfectly fine and then just shuts off. Posted via Mobile Device
06-04-2013, 04:53 PM | #8 |
I am pretty sure that is how the VATS works. It lets the engine run for a few minutes then cuts fuel.
06-04-2013, 04:55 PM | #9 |
I would check your fuel pressure or if your pump is cutting out
