Old 06-05-2013, 11:12 PM   #1
Hardesty454
Hardesty454's Avatar
Bag kits
Hey guys. Been looking all around at suspension for MONTHS now. Debated pro touring style set ups. Looked and the standard static drops. Im about 75% set now
I've talked with a few guys that own custom shops and buddies of mine who run different set ups and they all are pushing me to go bags. I dont need to lay frame or anything but from what Im being told the ride benefit of bags is the overall best option. Do you agree?
So as Im shopping for bags I believe Ive settled on the Accuair E-level controller, seems to be the most advanced point and shoot install. Im new to bags so Ive been looking for stores and sites that sell kits. So far the best place Ive found is AVS here in central cal (Fresno) which is not too far from me. Their site is VERY user friendly and sets up your entire setup for you in drop box options.
All that for my main question; Where is everyone getting their bag set-ups, what brand and series (and why that brand if you dont mind), and what made you go with bags in the first place? (Im sure a lot of the answers will be you want to lay frame, but what other benefits over static drops).
Thanks for the help guys, Im VERY new to bags so any help is appreciated,
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 06-05-2013, 11:27 PM   #2
c10Dream'n
c10Dream'n's Avatar
Re: Bag kits
I'd be interested in this info as well. I'm planning on doing a 4/6 drop for the mean time, but would eventually like to get bags. I hear Accuair and Air Ride are the way to go, but it all depends on the setup.
c10Dream'n is offline   Reply With Quote
Old 06-05-2013, 11:37 PM   #3
Hardesty454
Re: Bag kits
I was debating the 4/6 for months from ECE as they are out of Fresno as well. But I would hate to spend the $800 or however much their kit is and then want to go lower or not like the stance. Im more into the bull dog muscle look rather than the small rake a lot of guys run.
Rob
Old 06-06-2013, 10:40 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bag kits
Get everything from ECE for the 4/6 drop,... EXCEPT the coil springs.
Replace the springs with 2600 series bags.
(I like RE-7's or SS-7's from Slam Specialties)
Bolt the rear bags directly to the frame and use bag plates & cups up front.
Then just add your air management.
Keith
Convert to disc brakes.
Old 06-06-2013, 01:15 PM   #5
Hardesty454
Re: Bag kits
Everything as in the shocks, relocators, what else? I already have drop spindles.
Rob
Old 06-06-2013, 01:17 PM   #6
lolife99
lolife99's Avatar
Re: Bag kits
drop shocks (front and rear)
rear shock relocators
ECE Super Track bar.
Personally,... I would add a bolt in c-notch and 2" drop blocks for the rear.
C-notches can be purchased from Porterbuilt, CPP, McGaughy's, or Performance Online.
Keith
Old 06-06-2013, 02:07 PM   #7
71chevswb
Re: Bag kits
Smart. I've never thought about this option. I will seriously consider this! Thanks for the idea. I already have the ece 4/6 so I just need some bags and accuair.
71chevswb is offline   Reply With Quote
Old 06-06-2013, 05:44 AM   #8
Square_78
Square_78's Avatar
Re: Bag kits
I have the Accuair eLevel and its by far the best system out there. Is all plug n play, the EXO mount ties it all together in one easy to mount package and the eLevel system is amazing. The ride is better than any static drop suspension. If you want the ride stiffer, you just add more air. Easy.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-06-2013, 09:49 AM   #9
71chevswb
Re: Bag kits
Square_78 : do you have any pictures of your Exo accuair mount? I'm curious where you mounted it. I have a shortbed so I guess your setup might not work on a shortbed but I would love to see how you did it! Sounds like a killer setup!!
I have done a bunch of static and bag research. I had planned on getting the accuair elevel kit and ride tech stage 2 bag kit (minus the tank and controller). When I priced out what I wanted, it was a bit over my budget so I went with EVe 4/6 static kit and am in the process of restoring my frame and all the suspension. I still have regrets that I should have gone bagged because I want a good ride and I was a bagged stance and the adjustablity. I will eventually go bagged but my wallet didn't support it at the time. I would definitely say accuair elevel is the only way to go and I think the ride tech kit is a good one but not sure the best but still very good.
Old 06-06-2013, 06:51 PM   #10
Square_78
Square_78's Avatar
Re: Bag kits
My EXO mount is bolted to the side of the frame (drivers side) between the cab and the rear wheel. It's pretty hard to see or take pics of. It tucks perfectly under the side of the bed.
#teamlongbed
Old 06-06-2013, 10:04 AM   #11
Hardesty454
Re: Bag kits
Where did you get your set up?
Rob
Old 06-06-2013, 10:35 AM   #12
clayton1967
clayton1967's Avatar
Re: Bag kits
I would also be interested in this info as im gonna be ordering my kit at the end of the month!
1967 chevy short wide, 327, muncie m20 4spd, 3.73 gears
2001 gmc denali
clayton1967 is offline   Reply With Quote
