Old 06-08-2013, 07:43 PM   #1
Gigem
Gigem's Avatar
Question New turn key crate motor backfires through carb
Brand new GMPP 350 HO crate motor. "Turn key", came with Holley 650.
Doesn't happen all the time, but every once in a while it backfires through the carb on acceleration. Sounds like a sneeze. Seems to happen more when I am driving the car easy. Otherwise seems to run great.
Timing was way off out of the crate, but is right now.
Any guesses? Or ditch the Holley and get an Edelbrock carb, as a buddy suggested...
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 06-08-2013, 08:05 PM   #2
wraprail
wraprail's Avatar
Re: New turn key crate motor backfires through carb
For what it must have cost ($$$$$$$$$$$$$!!!!) I would expect it run perfectly!
Get on the phone with whoever sold it to you.
Demand they make it right...Or else!
wraprail is offline   Reply With Quote
Old 06-10-2013, 11:43 AM   #3
BurnoutNova
BurnoutNova's Avatar
You have to be able to tune the carb and make sure the timing is right. I know there are alot of carbs out there that say they should be good to go out of the box, but if you expect it to run perfect you need to tune it to some degree..
There are to many variables to make a carbureted engine run perfect in every situation. Altitude, humidity, vehicle weight, etc all come in to play.
BurnoutNova is offline   Reply With Quote
Old 06-08-2013, 08:33 PM   #4
79Betty
79Betty's Avatar
I agree. If i'm going to spend that kind of money IT WILL BE RIGHT OUTTA THE BOX.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 06-09-2013, 03:19 AM   #5
jon75
jon75's Avatar
I doubt there is anything wrong with the engine at all. It's funny you say you have a Holley carb on there. My buddy has a '67 Nova with the same exact setup and his hickups when trying to accelerate heavily. I can almost guarantee you that if your timing is set correctly, that your jetting or mixture is off. Sure, you might get good acceleration or power with a rich mixture, but when the engine can't burn all the fuel that Holley is trying to stuff in there, it will come back and burn right up through the intake manifold.
Solution? Take it to someone who knows how to adjust the carburetor for you or learn how to do it yourself. I went with Edelbrock simply for the ease of adjustment and have always had great luck with their products. Good luck.
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 06-09-2013, 03:34 AM   #6
V10farmboysdream
Cool Re: New turn key crate motor backfires through carb
My 383 did the same thing with my eldo 600. Another notch down on my excelerator linkage and the cough was gone. Can't comment on a holly. To touchy for this shade tree phd
V10farmboysdream is offline   Reply With Quote
Old 06-09-2013, 09:06 AM   #7
Vader85
Vader85's Avatar
I had the same problem on my Camaro. Turned out to be the accelerator pump adjustment. I looked down the carb and slowly opened the throttle, I noticed that the throttle would open a good bit before fuel would start to come out of the squirter. I adjusted it until I would see fuel come out of the squirter as soon as the throttle started to open and had good steady stream.
1985 High Sierra
http://s47.photobucket.com/user/jst8...ary/1985%20C10
Vader85 is offline   Reply With Quote
Old 06-10-2013, 11:10 AM   #8
tony58
Lean condition causing the backfire. Can be either mixture or accel pump, probably accel pump. Wouldn't hurt to triple check that it has enough timing also.
tony58 is offline   Reply With Quote
Old 06-10-2013, 03:35 PM   #9
Blackpony
Blackpony's Avatar
Sounds like the carb needs to be dialed in. Even though its a turn key crate motor, it will always need to be fine tuned.
Blackpony is offline   Reply With Quote
Old 06-10-2013, 09:38 PM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
take the truck to www.bumberas.com in katy and tell them your problems and that you need a tune. They work on classics everyday and are very familiar with carbs.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-24-2013, 02:02 PM   #11
Gigem
Gigem's Avatar
Problem solved. Power valve. Ended up replacing Holley with Edelbrock 650 anyways. Runs awesome now!
