I Keep popping 15 amp fuse
I Keep popping 15 amp fuse on my wire coming off back of alternator going to my "hot" power block
Does my wiring seem correct, it is based off research i did on this site and other forums. Battery has 2 wires - 2ga to post of starter - neg to frame Starter has 3 wires -2ga from + batt - 10ga from big post to back of alternator - purple wire from factory harness to little post Alternator has 3 wire - 1 wire in plug that goes into computer - 10ga coming from large post on starter - 10ga with 15amp fuse going to constant "hot" power block Harness only had 3 relays Fans, Fuel pump, IGN. (no other fuses) - 2 wires coming off relays that called for "key hot" - 5 wires coming out of harness and relays that called for "12V hot" - 3 ground wires - relay ground wire Headlights/gauges are running off the stock harness/fuse box Truck is running very rough and will barley idle. Seems to be misfiring
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
![]() Join Date: Sep 2005
Re: I Keep popping 15 amp fuse
15 amp doesnt sound high enough depending on whats running out of that hot box
The hot box is running the relays for the fans, fuel pump and ignition. Along with power to the PCM and obd2 port.
Your pulling to much juice though a 15 amp fuse
x2...overloaded!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
it probley should be around a 30-40 amp fuse i'd say
Awesome thanks. I'll through in a 30 amp and she what happens.
Tags |
electrical, electrical short |
