E-fan relay ?
I get a clicking noise form the second elec. fan relay when it want s to come on. I've tried switching relays and it still does it.....the first fan comes on when its supposed to and works perfectly, but the second fan relay just clicks....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
meowMEOWmeowMEOW
Re: E-fan relay ?
fan motor seized up and drawing too much current, popping the relay?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: E-fan relay ?
Is this a new install or did the second fan work in the past?
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
Re: E-fan relay ?
this is a brand new rad and e-fans.....the second fan works, but it never ever has come on when the pcm calls for it to come on. just the clicking in the relay.....I just put it off to being something wrong in the tune...?
Re: E-fan relay ?
How are the relays wired.. Could it be a problem with the wiring? The factory wiring normally (the ones I know of) have 3 relays and run both fans at half speed or both at full speed. I am not sure what you have for your setup.
Re: E-fan relay ?
it's a PSI harness, and I tried switching the wiring and it still didn't matter, whatever fan was #2 the relay still clicked....
Re: E-fan relay ?
Does the second fan work when you put 12VDC to the hot side of the fan?
Always a work in progress
Re: E-fan relay ?
I have the exact same issue. It is only on the 2nd fan relay. I can take the signal wire and swap them on the relays and the fan works just fine. I just hooked up a switch to control the 2nd fan until I can find out why it does that.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: E-fan relay ?
both relays are wired the same, both fans work when hooked to 12v direct...so now I just wired both fans from the #1 signal wire, so when it comes on, both fans work...
![]() Join Date: Apr 2005
Re: E-fan relay ?
Disconnect the computer signal to the #2 fan and trigger (ground) it manually. If that works then there is a problem with the computer or the tune. If it doesn't work, something is wrong with the way the #2 relay is wired.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: E-fan relay ?
ok i had the very same problem, i had the a/c pressure set to zero in the tune. i dont have the a/c run to the PCM, but its still looks for it.
i set the a/c pressure way up and it stop doing it and fan 2 operates properly now. i had to figure it out by going on HP scanner and manually turning on fan 2 and it work fine, so i knew it was something in the tune. hope this helps.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
Re: E-fan relay ?
Re: E-fan relay ?
thanks I'll give that a try.....
Re: E-fan relay ?
tried that out today....#2 fan comes on when ya ground the relay, so now what?....lol
#15 |
Re: E-fan relay ?
did you check the A/C settings in the PCM?
thats what was wrong with mine.
#16 |
Re: E-fan relay ?
umm...yeah. I got no way of doin that...
#17 |
Re: E-fan relay ?
remind me how did you get your anti theft turned off in the beginning?
you may have to get a tuner to look at it for you. everything you described, sounds just like the problem i had. i could be wrong, but you have already tried all the simple stuff.
