Old 06-10-2013, 09:31 AM   #1
Steve Cole
Info needed from the Turbo 400 guys!
Could someone please post some pics showing the proper routing of the wire harness for the pedal mounted T400 kickdown switch? I did a search but didn't find anything.
Thanks!
Steve Cole is offline   Reply With Quote
Old 06-10-2013, 10:48 AM   #2
Steve Cole
Re: Info needed from the Turbo 400 guys!
Beuller?? Anyone?
Old 06-10-2013, 08:54 PM   #3
Steve Cole
Ttt.. Anyone????
Old 06-11-2013, 12:32 PM   #4
Steve Cole
No one? Seriously?
Old 06-11-2013, 12:40 PM   #5
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
Try the engine and drivetrain section . That may help .
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 06-12-2013, 03:05 AM   #6
67chevy1series
67chevy1series's Avatar
The switch is on the gas pedal bracket for 71-72.. But where is the kick down switch on a 67-70? That's something I've been wanting to know for a long time
67chevy1series is offline   Reply With Quote
Old 06-12-2013, 03:24 AM   #7
Artikgrau325is
I believe the switch is mounted on the side of the carburetor. At least, that is what I concluded when I did research on how to hook it back up after putting an Edelbrock 1406 on it (I used a nitrous micro switch.)
I'm sure one of the fine posters here has more adequate info, but if there's no responses here I'll take a picture of the factory kickdown on the carb for ya.
Artikgrau325is is offline   Reply With Quote
Old 06-12-2013, 08:12 AM   #8
twich3136
twich3136's Avatar
i have a th400 with the kick down switch but im pretty sure its supposed to attach to a bracket by the gas pedal. mine was "rigged" to work off the quadrajet. i switched to an edlebrock and couldnt get it to work, so i just tied it up. i have researched it before and im fairly cirtain its supposed to be on the gas pedal.
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 06-12-2013, 08:30 AM   #9
Robznob11
Robznob11's Avatar
Push button in cab on shift handle works cool.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-12-2013, 08:48 AM   #10
Steve Cole
I know my switch attaches to the pedal assy., what I don't know is how the harness is routed from the switch to the tranny. Anyone have pics of this?
Old 06-12-2013, 09:45 AM   #11
twich3136
twich3136's Avatar
i found this on google. its a bit of reading but it might have the answer your looking for.
http://www.google.com/imgres?imgurl=...ed=0CEYQrQMwDQ
it looks like you just run one wire up to the the switch and a hot wire to the fuse block.
USMC
SEMPER FI
Old 06-12-2013, 09:50 AM   #12
twich3136
twich3136's Avatar
67chevy1series
if i understand right this is the older switch
this is the 71-72 switch
USMC
SEMPER FI
Old 06-12-2013, 10:36 AM   #13
Steve Cole
Not what I am looking for but thanks anyway. I want to see the path the wire takes as it goes from the switch, through the cab, exits thru the firewall and connects to the tranny.
Old 02-06-2014, 10:30 PM   #14
turp mcspray
turp mcspray's Avatar
The wire runs through the same hole/grommet as the oil pressure line, down through the firewall tabs, with the taillight wires, and on to the trans. Sorry, I don't have any pics. Hope this helps!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-07-2014, 01:00 AM   #15
Steve Cole
Thank you Turp! Even without pics, this is the best answer yet.
Old 02-07-2014, 11:27 AM   #16
72junky
Same here Turp! That was a BIG help! by the way, I like your picture... Hope you didn't get hurt and the truck survived too.
72junky
72junky Don't worry my wife said it's ok.
'72 K10 custom/10 350/4spd,ps,pb,ac,tilt,tach,3:73 posi,buddy buckets - driver
'72 Cheyenne/10 swb 355/th350,factory black, loaded and lowered - toy
'72 Cheyenne/10 lwb, 350/th350,ps,pb,ac,tilt - current project build
'72 K5 Blazer CST 350/th350,ps,pb,ac,tilt,tach,3:73 posi - project rust bucket -Unfortunately Sold
plus 4 others too ashamed to post
72junky is offline   Reply With Quote
Old 02-07-2014, 03:09 PM   #17
turp mcspray
Thanks! I wish it was a better pic. My left front tire wasn't to the top of the rock yet, so it actually went a little higher. My wife and kids were with me, and nobody made a peep! It felt like it was going to go over from the driver seat! It survived that rainy and slippery day, but over all, the rock crawling really took a toll on the old blazer.
Turp Mcspray
