Old 06-11-2013, 05:50 PM   #1
82ccshorty
82ccshorty's Avatar
bagged or lowered crew cab pics wanted
can some of you guys with bagged or lowered crews put up some pics? im trying to decide between bagged or just lowered. thanks
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 06-12-2013, 12:02 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: bagged or lowered crew cab pics wanted
Here is mine bagged with stock AC and bed floor
bagged74 is offline   Reply With Quote
Old 06-12-2013, 12:03 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
Old 06-12-2013, 10:08 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Man,... that thing looks good.
What cool trucks do you have now?
Keith
Convert to disc brakes.
Old 06-12-2013, 11:03 AM   #5
bagged74
its just $$$$$
bagged74's Avatar
Old 06-12-2013, 11:07 AM   #6
396ci
396ci's Avatar
That is WAY cool!
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 06-12-2013, 12:18 PM   #7
lolife99
lolife99's Avatar
Originally Posted by 396ci View Post
That is WAY cool!
X2!!!!!
Keith
Old 06-12-2013, 12:17 AM   #8
cochino12
It followed me home?
cochino12's Avatar
I thought you sold that truck? looks good. Are you running cups/plates in front or do you have cupped/tubular arms?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-12-2013, 08:12 AM   #9
bagged74
its just $$$$$
bagged74's Avatar
I did sell it. I've had two others since then. It had cupped lowers and tubular uppers on it
Old 06-12-2013, 03:39 PM   #10
SCOTI
SCOTI's Avatar
It looks a little different these days. They're sporting some 24x14 Intro's w/the 405mm tires out back which required a narrower rear housing & a triangulated 4-bar. Oh yeah... no mo bed floor....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-12-2013, 05:37 AM   #11
82ccshorty
82ccshorty's Avatar
Which would you recommend for a truck I'm Guna be driving daily?
Old 06-12-2013, 10:19 AM   #12
bagged74
its just $$$$$
bagged74's Avatar
I drove that one daily, it just depends what you want.
Old 06-12-2013, 01:23 PM   #13
bagged74
its just $$$$$
bagged74's Avatar
Thanks guys, sorry for the thread jack 82ccshorty
Old 06-12-2013, 02:25 PM   #14
bohmankid
bohmankid's Avatar
Wouldn't bags be better for a daily driver instead of a static drop? Just more expensive...
bohmankid is offline   Reply With Quote
Old 06-12-2013, 03:48 PM   #15
82ccshorty
82ccshorty's Avatar
I think I'm Guna go with air. I talked to azproperformance.com and they said they could do pretty much everything for 6200. Which was porterbuilt front and rear drop member compressors tanks everything. Sounds pretty fair to me.
Old 08-19-2013, 10:23 PM   #16
Bczik84
This is probably a dump question but if you run bags do you ruin a lot of front tires. Or is there a system that will keep truck at a level that wont effect tires like the Lincoln mark 8 cars
Bczik84 is offline   Reply With Quote
Old 08-20-2013, 08:47 AM   #17
SCOTI
SCOTI's Avatar
Align the truck @ ride height. Return to that height for ideal alignment & minimal wear. Any other height & the wear excells.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
