06-11-2013, 10:28 PM | #1 |
VA72C10
Need power steering low pressure fitting
Need the fitting that screws into the box and has a short section of metal tubing that you put the power steering hose onto. I have a new high pressure line but haven't been able to locate my low pressure fitting and the ones I've sen in the parts stores haven't looked correct.
Looking for a 67-72 swb or blazer project in or around VA. |
06-11-2013, 10:42 PM | #2 |
Re: Need power steering low pressure fitting
I bought my return hose from advance auto parts and it had that fitting in the hose witha pressure clamp just srew in and go ill see if i can find the number for u
06-11-2013, 10:46 PM | #3 |
06-11-2013, 10:48 PM | #4 |
06-11-2013, 10:53 PM | #5 |
VA72C10
Thanks a ton! I had them look it up in the store and they couldn't find anything. I will call and see if they stock either of those part numbers or order it.
06-12-2013, 03:25 AM | #6 |
Np i broke mine i thought i was screwed till i found thoses
06-15-2013, 08:59 PM | #7 |
VA72C10
looking at that again and it comes straight up. That would be into my inner fender...will see if I can bend it but does anyone else have an option they've used that looks more like the high pressure hose that lays flat against the frame with a tight bend coming out of the ps gearbox? Thanks
06-15-2013, 09:04 PM | #8 |
VA72C10
See this drawing on LMC...I can order one of these but would rather pick one up local because I need it within the next week.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=128
06-15-2013, 10:17 PM | #9 |
Jonathon, Inline tube carries the correct one. I do not think I have in stock but I will check for you tomorrow
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
06-15-2013, 11:10 PM | #10 |
VA72C10
Thanks Bill
06-18-2013, 10:46 PM | #11 |
I'd be interested in one too...any pictures to verify? Thanks!
06-20-2013, 10:00 PM | #12 |
Sorry, did not have any in stock
06-20-2013, 10:40 PM | #13 |
VA72C10
Thanks for checking. Do you know the correct part number by chance?
06-21-2013, 08:30 PM | #14 |
Cts7101
06-21-2013, 08:34 PM | #15 |
VA72C10
Thank you very much! Have a great weekend!
06-21-2013, 11:08 PM | #16 |
I need one too!
LMC charges too much for shipping when you just buy a cheap part or two, it's not worth it. Last time I paid almost 11 dollars shipping for a 5 dollar part. Posted via Mobile Device |
