06-12-2013, 10:36 PM | #1 |
10 bolt rebuild questions
So I have my 10 bolt mostly torn apart, and I have some questions. First off, it had a snapped driver's side axle when I bought it (shame on me for assuming) which is why I'm tearing it down. Should I replace both inner and outer axle shafts, or just the broken inner and put a new U Joint in? Also, should I replace the inner seals? I have not torn the r&p out yet, and honestly I'm a little scared to. Should I replace the U Joint on the passenger side. Last one...has anyone had experience with Rugged Ridge locking hubs?
Sorry for the long-winded questions, I'm just curious how deep I should take this rebuild. I am already planning on replacing the ball joints which is another reason I tore it down as far as I did. |
06-12-2013, 10:57 PM | #2 |
Re: 10 bolt rebuild questions
when you slide the axle shafts in you might nick the inner axle seals and cause a leak anyways. its only four more bolts. you dont have to re set gears or anything. remove and replace.
and if you only do one ujoint the other one is gonna laugh at you two weeks later and youll have to change it anyways. just replace the broken axle shaft. theyre not much to go wrong with those. if they ujoint caps spins in the yoke ear, its bad too. should not be re used. |
06-12-2013, 11:14 PM | #3 |
Ok, that makes sense. So since it makes sense to pull the diff out to replace the inner seals, it probably makes sense to replace the pinion seal as well right? Does that require anything special other than replacing the crush washer (and setting the drag or whatever it's called)?
06-12-2013, 11:48 PM | #4 |
If the pinion seal aint leaking its fine. The pinion assembly requires a crush washer. This is not a remove yoke and seal and replace kind of deal. The crush washer sets pinion bearing preaload and if youre not comfortable setting up gears then id leave it alone. Youre looking for like 18 inch pounds of rotational torque on the pinion.
Posted via Mobile Device |
06-12-2013, 11:51 PM | #5 |
Ok, so pull the diff out and I'm ok. Remove the pinion and I'm screwed. Got it
Thank you for your help on this obijuan! |
06-12-2013, 11:58 PM | #6 |
In a nutshell yes. While youre in there, take a rag on a broomstick or something and scrape out the inner axle tubes.
06-13-2013, 12:00 AM | #7 |
Also there are left and right bearing caps. And up and down. Mark them with a punch to identify orientation. Also races need to go back on the same side.
They may even be marked already. Posted via Mobile Device |
06-13-2013, 12:01 PM | #8 |
Thank you for all your insight on this obijuan!! I may even have the balls to attempt this over the weekend
06-13-2013, 01:53 PM | #9 | |
Hundred, or perhaps thousands, of pinion seals are replaced every day without a rear axle overhaul. The trick is putting the pinion nut back where it came off.
06-13-2013, 02:18 PM | #10 |
Show me where it says count the threads. Thats not the right way to do it. The op comfort level doesnt seem up to where he wants to chance ruining a crush sleeve. Millions also dont have crush sleeves. If it were a dana 44 id say r&r hammer that pinion nut on.
06-13-2013, 04:28 PM | #11 |
A dana 44 has a 10 bolt cover and I think that is what the OP is working on.
So no crush sleeve to worry about. PS, I don't count threads
06-13-2013, 07:08 PM | #12 |
well judging by him saying ten bolt and his build thread has pictures of a ten bolt, its gotta be a dana 44. i guess i just assumed.
06-13-2013, 07:34 PM | #13 |
I didn't read his build. Doesn't matter anyway.
I did pull out my service manual. You should read it sometime.
06-13-2013, 09:55 PM | #14 |
Hey be nice you two :-) it is actually a 10 bolt that I purchased to replace my closed knuckle 44 so that I could get disks on the front. Obijuan is right, I'm not overly excited about having to deal with the preload, but then again I can do anything with the right tools and knowledge from the board
06-14-2013, 06:33 PM | #15 |
hey mrjensen I don't know about those rugged ridge locking hubs, but my I got my Mile Marker premium hubs from Amazon for like $75 shipped. Mine are PN 104, but you need to double-check the fitment on yours because I think you have an 8-lug front end.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
06-14-2013, 09:44 PM | #16 |
Ok, I'll check that route! Thanks!
06-15-2013, 10:12 AM | #17 | |
I am always the one to caution people about messing with things that affect the set-up of the gears....but I'm with Bigdav160 on this one.
You can change a pinion seal w/o hurting anything. First of all, the "rotating torque"spec is for "when new", meaning freshly installed. You can actually change the contact pattern by tightening your "used" bearings to that point. The nice thing about this is that it takes an incredible amount of force to crush the sleeve, more than you would apply when reinstalling the yoke. I would use a new nut and torque it to 100-125 ftlbs and call it good. Of course use some common sense here. You are doing this "by hand", so stop if anything "feels different".
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-15-2013, 10:20 AM | #18 |
All ten bolt lockouts will swap with internal style dana 44. Theyre 19 splines. I prefer the spicer style hubs myself. Warn premuims are excellent though.
the external style was 8 lug dana 44s from way back. They bolt on with six 1/2" bolts or so. The internal style is the same lockout from waggoneer, and f150's, 250's l, k5, k10, k20, broncos, dodge dana 44s too. Posted via Mobile Device |
