Old 06-13-2013, 03:06 PM   #1
68350
68350's Avatar
bypassing blinkers wiring help
So found out yesterday that there's a bad wire somewhere in behind my fuse block. I don't really want to tear apart all of the wiring so I'm wondering if I can bypass the wiring and get my blinkers to work. So I pulled relay from fuse block(has power to relay). I hooked up a jumper wire to power side of relay and ran a wire from relay to purple blinker wire in column wiring. The other terminal of the relay I plugged back in to fuse block. So when I was all done, the blinkers will light up, but they don't flash. Anyone have a suggestion on what I did wrong to jump the relay over? I want my blinkers to work, as everything else seems to work. Thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 06-13-2013, 03:25 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: bypassing blinkers wiring help
I believe that relay is the flasher, have you tried to replace the flasher with a new one?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 06-13-2013, 03:32 PM   #3
68350
68350's Avatar
No I will do that when I get home. That would be awesome if that was the issue
Old 06-13-2013, 03:50 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
What you are calling a relay is the flasher and it is nothing but a spring loaded wire in a can that reacts to heat caused by current running through it. When the current runs through it to the turn lights on, it heats up and distorts so the connection inside is broken, and the lights will go out. As soon as it cools a little, it springs back to make contact with the output side again, and the lights light up again. The cycle repeats until the current is removed..
If you run a wire that is hot with the key on, to either terminal on the flasher and then run a wire from the other terminal to the purple wire on the column connector, it should work as normal.
The flasher terminal is fed by the stop/turn/tail fuse in the fuse panel so if there's a break in the power to the flasher it will come from there.
You might be able to remove the two mounting screws on the fuse panel and get to the back of it without removing any wires. It's been a long time since I had mine off, so I don't remember.
Follow the purple wire that the blue arrow is pointing to, back to the fuse panel (down and left) and you'll see where it connects to the fuse box and one side of the flasher. The other side is fed by the fuse and key on power.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-21-2013, 03:43 AM   #5
dazza
dazza's Avatar
Thanks Vet! You've answered another one. I was just searching and doing a lot of reading the last hour or so trying to figure out the last electrical issue (for now anyways) I had, why don't my signals work??...
And your last sentence here slapped the inside of my skull!
oh, yea, gotta turn the damn key on!
Thanks again and let me know when you have that online beer-fund set up so that I may contribute!!
-daz
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
