Old 06-15-2013, 08:05 AM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Turn signals don't work
I did a lot of googling but couldn't find info on this particular issue. My turn signals don't work but my hazards do. The only 12v supply I get over the 8 steering column wires is on the black horn wire. I did do a painless harness about four years ago but I think the wire colors are similar. My brake lights and headlights all work. I tore the turn signal switch apart and I would think that either the brown wire or the white wire would power the switches. What wires should power the switches? I just put in a new turn signal switch about a year ago.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-15-2013, 01:33 PM   #2
domeier
domeier's Avatar
Re: Turn signals don't work
This should help:
Black in, is horn power
Purple in, is power from the turn signal flasher relay
Black/White in, is power from the stop lamp switch
Brown in, is power from the hazard flasher relay
All grounds are made after the lamp elements
Turn indicators in dash are powered off the front turn lamps
Left turn:
Purple in to switch goes to Black/yellow out (left brake/turn lamp)
Purple in to switch goes to Black/Blue out (left front turn lamp)
Black/White in to switch goes to Green out (right brake/turn lamp)
Right turn:
Purple in to switch goes to Green out (right brake/turn lamp)
Purple in to switch goes to Blue out (right front turn lamp)
Black/White in to switch goes to Black Yellow out (left brake/turn lamp)
No turn:
Black/White in to switch goes to Black/Yellow out (left brake/turn lamp)
domeier is offline   Reply With Quote
Old 06-15-2013, 02:18 PM   #3
Wrenchbender Ret
Its more then likely the fuse or flasher. The turn signal flasher is separate from the 4 way.
Wrenchbender Ret is offline   Reply With Quote
Old 06-16-2013, 09:53 PM   #4
JayDubBlazer
go cyclones
It was the flasher, the flasher was only used for about 100 miles so I didn't think of that.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 06-16-2013, 09:54 PM   #5
JayDubBlazer
go cyclones
And thanks for the help
Wes
PROJECT OLE GREEN
2017 Silverado LT
