Dude...I'm a CHICK
VIN help please!
I FINALLY saved the money to get my truck transferred over to Fl from Ga. I went into the tag office with EVERYTHING I needed. When she took my Ga title out to compare it to the VIN plate on the door sill, there is one number and one letter that does not match.. What the HECK?! Here is my question. Where else should the VIN number be printed on my truck. If it ever was, it is no longer on the dash.
Thanks !! junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
Re: VIN help please!
I know that many VIN,s from old vehicles don't "conform" to the current DMV VIN criteria....maybe Ga added some characters to bring it into compliance? I would start with contacting Ga DMV.
Posted via Mobile Device |
![]() Join Date: Oct 2012
should be on the top of the drivers side frame around the area the ps pump is, as long as the frame is oe to the cab it will match the cab numbers
Dude...I'm a CHICK
slow-1 that's what Im thinking, but try to convince the tag office of that.
c10, I looked and even stripped the paint off the frame by the pump and cannot see anything. That I know of, it has never had a frame off.
could be a mistake on dmv's end......it happened to me. and lucky for me i caught it now while the truck is new to me, rather than a few years down the road.
bought my truck a few months back and after i filled out the "new owner" info, they mailed me my pink. I have had some problems with getting it registered. Long story short, DMV changed a "Z" in my vin to a "2". so now i have to bring the truck down to dmv on friday and have them look at my vin # to verify before they can correct it and send me a new title. good luck with your truck!
1970 Chevy C10 Fleetside SWB 1998 Dodge Viper RT10 1999 Harley Road King 2006 Ford F250 CC SWB 2008 GMC Yukon Denali My Build Thread |
Dude...I'm a CHICK
Jerry, that's exactly what Im having to do. The main lady at the tag office is supercool. I have to meet with her personally next week . She called me back and I told her that I didn't know if it mattered or not, but that I still have the original SPID sticker on the inside of the glove box. She said to go ahead and look closer to see if I can find the VIN stamp on the frame, if not we will see if we can make the SPID work. Keeping fingers crossed!!! Thanks darlings!!!!
![]() junk
I believe the ones the frame horns is only a partial vin so that really wouldnt help. My 70 k5 has a partial on each side of the front frame.
Generally they are the plant code and the unit serial number (the last seven) IIRC. Bruceman1968 will know!
What are the two different characters? You can use the decoder linked in my signature to breakdown what you have for both the VIN code and the model code.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 06-17-2013 at 03:40 PM. |
#9 | |
A VIN of CS148S100001 will be 8S100001 on the frame. Some frames did NOT get stamped, and some are 1 number off. Here is where you should find the stamp. If you don't have a partical here, then there probably isn't one under the cab either. (check anyway)
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 06-17-2013 at 04:14 PM. |
Junkie, Match the door VIN plate number to the SPID VIN number and take a pic of both. If they are exactly the same then, The title is off probably from the georiga DMV. I don't think you will have to much trouble getting the title changed to what it should be.
If you need to look for the parcial vin under the cab, use a dental mirror to see it.
CHEVY/GMC VIN DECODERS |
Old Skool Club
![]() Join Date: Jun 2001
On my truck, the VIN that is stamped into the top of the left side rail is beneath the cab.....If yours is there, it's gonna be tough to see without a left-handed corkscrew mirror camera....and a double-jointed neck on top of your shoulders...
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
in new York its easy...you just look thru the rust hole in the floor
#13 | |
![]() Join Date: Dec 2012
![]() sad but true
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model ![]() |
One of the First
![]() Join Date: Jan 2000
3 things to verify matching numbers - Frame, vin plate and spid sticker = title.
Thought, If you have a friend that is a police officer, notory, they can sign off on the verfication form...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#15 |
Dude...I'm a CHICK
Ok, I have looked on the frame, razored 19 hundred layers of paint off and I see no gosh darn numbers. The numbers on the SPID, or Data plate match the door plate perfectly. The numbers were changed when I registered in Ga from CA. I don't know the meaning of their madness but it has totally messed me up. Ga changed a 2 to a Z and added a 7 right in the middle of the number. The lady I talked to that is the head person in the tag office seems really cool. She has been out of town. As soon as she gets back, I can take it to her and she will most likely sign off on it. Just a big bunch of hassle. Ill update as soon as I can get an appt. with her, I appreciate yalls help. I just couldn't do stuff without yall!! THANK YOU!!
junk
#16 |
You're in luck ! .
What you need is called a " Title Correction " and since she mentioned it , just keep your mouth shut and she'll handle it . My '69 C/10 doesn't appear to have a frame stamp (dammit) and so far , none of the junkyard ones I've found do either . This bring up the need to always CHECK your documents and when there's a wrong , missing or additional digit , just go to the DMV and 8politely* mention they made an error and you'd like to get it fixed please . Doing this in the State it's currently registered to you in , is the simplest way to go , even if you're planning to move or sell it~ having correct , matching title and reggie , protects YOU and $aves $ in the long run , every time .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#17 |
Dude...I'm a CHICK
California and the deep south are different planets. This comes from a former California girl. The lady never mentioned anything about a "Title Correction". The numbers on the title don't match any number that I can provide.. She has to have concrete evidence that the error is only on the title (human error), and not because someone is trying to pull something illegal, ie numbers on the frame.
#18 |
GMC Junkie, I think your next trip to the DMV will be a breeze. No problem at all.
The 2 that was changed to a Z, must of been the 3rd digit of your VIN. That's the GVW Range spot. There are no GVW Range codes that are a letter. They are all numbers. This can be easily documented. On the 7, since it is NOT on the Vin plate or the SPID, and with the other error you won't have any trouble showing them that it,s a error on the title Also it would make the serial number part of the vin 6 numbers long, and all the serial numbers (for a 71 GMC, USA Built) were only 5 numbers long. Also easily documented. Here is a decoder for your 71 GMC. Which by the way is absolutely stunning. love the color, and I still can't believe it climbed that hill at the Arches. ![]() Might help the DMV see why the title has to be wrong.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 06-24-2013 at 03:19 PM. |
#19 |
Funny how that decoder page turned out a 71 K1500 Suburban by chance... There was a reason for our choices there Bruce!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#20 |
Dude...I'm a CHICK
Bruceman, that diagram makes sense. The only thing that was changed on mine was, on my truck, there is a Z where indicated on the diagram, Ga tag office changed that Z to a number 7. The lady was supposed to call me back today if she got any information from HER supervisor. Havent heard from her yet. Thanks so much everyone for your help. Ill update as soon as I can get some info.
take care junk
#21 |
Ok, so you have a 7 in the assembly plant spot. It is easy to document that NO assy plant had a code of 7, so it should be easy for them to see that a human error was made on the title. Good luck Junky, I'm sure it will work out fine.
