Old 06-17-2013, 06:55 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Starter engaging while driving?
So I replaced my starter on my 88 last week. I didn't notice the knock sensor wire wrapped around it and accidentally broke it off. I left it like that and havent had any problems. Except, under hard acceleration I hear the starter engage for no more than one full second and it stops. Why is this happening? How do I fix it?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-19-2013, 10:21 PM   #2
thirdstreettito
Resident of Here
Re: Starter engaging while driving?
Bump. Anyone?
~Bradley~
Miss having a truck
Old 06-20-2013, 03:18 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
mine broke off and it would knock,SES light would come on
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-20-2013, 10:22 PM   #4
y5mgisi
Second Chance Program
y5mgisi's Avatar
Loose actuator wire at the starter rotating into the positive would be my bet.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-21-2013, 04:17 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
X2 check and be sure all the wires are not touching and tight.
WIDESIDE72 is offline   Reply With Quote
Old 07-29-2013, 11:35 PM   #6
thirdstreettito
Resident of Here
Could you explain that to me a little more? There is an actuator wire? Which one is that?
~Bradley~
Miss having a truck
Old 06-23-2013, 07:33 AM   #7
thirdstreettito
Resident of Here
Ok so after having my dad ride with me and hearing it, its not the starter or a timing ping. It happens at about 2300rpm under 3/4+ throttle. It definitely is a grinding. Im clueless.
~Bradley~
Miss having a truck
Old 06-24-2013, 08:22 PM   #8
y5mgisi
y5mgisi's Avatar
I once had the harmonic balancer rub on the front cross memeber.
Old 07-30-2013, 02:01 PM   #9
JCampbell
Detonating. Fix/replace the knock sensor wire.
JCampbell is offline   Reply With Quote
