06-17-2013, 07:51 PM | #1 |
Vortec 350 is anybody running one?
New to the forum great site. Just bought a southern 1968 GMC 2500. Though it's been in wisconsin for a decade it's solid. Ok now for details, custom camper, 3 tanks, 351 6 cyl, turbo 400, factory air. split bench seat. I know the 351 won't cut it how about a vortec 350 will it work? THANKS IN ADVANCE. MARK. Ps this is my first restoration.
06-17-2013, 09:14 PM | #2 |
Re: Vortec 350 is anybody running one?
I just installed $1940 to the driveway 4 bolt new chevy vortec engine in 99 k1500. It is a sweet running engine. My only complaint is: why the heck is that dang distributor stabbed in the rear; need to be Plastic Man to adjust it
06-17-2013, 09:35 PM | #3 |
Rufton, Thanks need info about putting it a 1968.
06-17-2013, 11:31 PM | #4 |
Hello Blackmaxx, welcome to the board.
See my 68 c10 build for Vortec swap information, I'm not quite done with the engine swap yet but there is more than enough information there to help you make a decision, there are also many other builds on here with Vortec swaps that are informative and can help you avoid pitfalls while doing the swap. |
06-18-2013, 12:53 AM | #5 |
The vortec should bolt right up. I'm running a 71 350 with vortec heads. The block is essentially the same. Just different heads with different angles and a better flow.
Posted via Mobile Device |
06-18-2013, 07:12 AM | #6 |
what needs to be done to use the efi? also how much will it devalue the truck swapping the motor?
06-18-2013, 09:52 AM | #7 | |
If your truck Isn't an all numbers matching truck with all GM sheet metal then it won't reduce the value at all but keep in mind these aren't high dollar potential collectables in the first place even if they are all numbers matching, all the money is in the restomod market with these trucks. |
06-18-2013, 09:46 AM | #8 |
If we are talking about the 96-98 vortec engines, It all bolts in the same but will have the same issues as newer EFI swaps like the LS guys. You will need to eliminate the catalytic converters, Have a custom tune including disabling the rear O2 sensors, disabling the VATS (vehicle anti theft system). I guess you could keep the cats and rear O2 if you wanted. You will need to either buy a high dollar harness or if you have a complete donor vehicle use the existing harnesses and eliminate 100? unnecessary wires.
You can find wiring diagrams on lt1swap.com, and if you create a free account on autozone.com, also alldata.com (pay site) There are 3 active members using this drivetrain: myself Harpie JohnT71 I have seen several others but not active members and dont remember their names or thread. only JohnT71 is actually "running" and here is a snip from his thread. http://67-72chevytrucks.com/vboard/s...51&postcount=7 I will try to answer any questions, and JohnT71 is a helpful guy also if you want to ask him since he is actually driving his
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-18-2013, 09:50 AM | #9 |
06-18-2013, 09:52 AM | #10 |
06-18-2013, 09:56 AM | #11 |
Programming can be done by many local tuners, which are popping up everywhere. There are also several mail order "tuners" Mail your ECM to them and tell them what needs done and they will mail it back. LT1 swap charges $75 according to their website, Street and performance is another big mail order tuner. http://www.hotrodlane.cc/
06-18-2013, 07:55 PM | #12 |
Thanks guys for the info.
06-19-2013, 12:18 PM | #13 |
Hey just ran across this I used a shop out of San Antonio Tx to program my computer they did the egr delete and vats and the o2 sensors and built me a amazing harness and it was at my door in two weeks. Im currently trying to finish up plumbing my fuel system and couple other things before my cab goes back on so if ya have any questions feel free to ask and I added the place I used contact info below for ya. And welcome by the way.
210.654.0774 11051 Wye Street San Antonio, TX 78217 www.fuelinjection.com |
06-20-2013, 10:12 AM | #14 |
Harpie thanks for the link and the welcome. Love this site learning so much.
11-19-2013, 12:11 AM | #15 |
A ... Hahjoel What yr motor you get those vortec heads from. .
