06-20-2013, 11:48 AM | #1 |
C50 Pick-up Drill Sergeant
This is one of two C50 pick-ups that I am currently building. One is a 3/4 ton 4wd regular cab step side pick-up truck (Drill Sergeant) will be a light tan color with a light brown interior.
The other will be a 1 ton 4wd crew cab fleet side. Have not decided on a big block or a 12 valve cummins yet but will decided soon. On Drill Sergeant I have had to make slight modifications to the firewall to change throttle from linkage to cable and to clear the valve cover on driver side. Here are some pics of both donor trucks- the red one is underway and is Drill Sergeant. The Blue will be a crewcab.
Randall Cowboy the 70' Crew Cab The DUKE K50 Crew Cab 2nd gen build thread Drill Sergeant The Ponderosa |
06-20-2013, 12:09 PM | #2 |
Re: C50 Pick-up Drill Sergeant
I LOVE C50's And ive Gotta whatch this SubScribed!
06-20-2013, 12:22 PM | #3 |
D@m^ Awesome trucks!
'69 Fleet It ain't yours, if you didn't build it! |
06-20-2013, 12:27 PM | #4 |
Im in too , I like the big toys .
06-20-2013, 05:06 PM | #5 |
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
06-20-2013, 05:29 PM | #6 |
those are cool.
you guys have your own section for those monsters. http://67-72chevytrucks.com/vboard/f...play.php?f=239 |
06-20-2013, 08:07 PM | #7 |
Junk Yartist
Subscribing to this one too
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
06-20-2013, 08:25 PM | #8 |
Subscribed
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
06-20-2013, 11:29 PM | #9 |
I really like those post '67 small back windows.
Do the right thing and go with a 12 valve. |
06-21-2013, 11:47 AM | #10 |
Took care of 95% of the rust which was the driver side inner and outer rocker and the front corner. Which obviously had to be hand made because its a C50. After unsuccessfully removing a good floor pan out of another cab decided to go ahead and just make one. Will post pics tonight.
I hate having to remove spot welds off of a truck that was made on Monday.
06-21-2013, 02:23 PM | #11 |
6>8 Plugless........
Great work Randall!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-21-2013, 11:08 PM | #12 |
Junk Yartist
I hate spot welds, period! Especially triple thick like the FREAKIN roof! You are now the official "How to do it better" builder.
06-22-2013, 12:33 PM | #13 |
First, to clarify, the front of the blue C50 will be going on Drill Sergeat which is the red cab. The cab of the blue will be the crew cab. (Hope that makes sense to everyone)
I have come to realize that most C50's have door to fender issues. This is because there is only one center body mount in the front. This picture shows the suspension mounting system that will also support the body on either side directly above the spring mounts. This should take care of fender to door binding. To the left of the picture below is the stock fender length and to the right is what I am cutting it down to. Still fit and re-fit body on body off, body on body off, over and over. But I'm getting closer to the look I'm looking for. These are NOT the tires that will be on it. This will have 16.5 deep dish hubcap wheels and about 38" tall mud terrain similar to the ones on my crewcab.
06-22-2013, 02:10 PM | #14 |
sweet start
06-22-2013, 05:13 PM | #15 |
Awesome Brother! Will be following you on this adventure!
06-22-2013, 08:08 PM | #16 |
haha that crew cabs gonna need like 54's to look right haha IMO
06-26-2013, 12:26 PM | #17 |
This is Drill Sergeant's frame modification all necessary to retro the C50 body to a C20 frame. Significant changes had to be made to the front of the frame, not only to support the cab properly but also to support the 4wd suspension better. After all this is also going to be pushing snow.
06-26-2013, 12:30 PM | #18 |
07-05-2013, 12:11 PM | #19 |
Small window to big window conversion
I was going to leave it a small window because I thought it would look good with the step side. There was so much roof damage, inner and outer, that I decided to go ahead and replace the whole thing with a roof that accepts a headliner, has the cargo light and is in really good shape. These pictures show the process of the conversion as well as installing a clearance light skin. Questions just ask.
07-05-2013, 05:42 PM | #20 |
Awesome! Subscribed.
"I feel the need for speed!"... as soon as I am done with my nap. |
07-05-2013, 09:34 PM | #21 |
I wish you were working on my truck.
07-06-2013, 12:43 PM | #22 |
Good God, where do I find such a fabricator?
07-21-2013, 01:26 PM | #23 |
Finished up all the media blasting except for the bed. Found only one area that needs a little bit of attention. Pretty well impressed with the overall condition of the sheetmetal on this project. The grill will need slight repairs and driver's fender will need a bit of reconstructive surgery other than that its etch primer and a little bit of body work. Also have the top of the cab painted white and masked off to do the rest.
Modified a regular truck door to fit C50 cab.
07-21-2013, 11:11 PM | #24 | |
Cool build ! Posted via Mobile Device
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
08-02-2013, 11:53 AM | #25 |
Haven't been able to work on drill sergeant due to other projects in the shop. I just put on these 37" military tires and hoping to have the cab on the frame today. All I have to do is seem seal and undercoat the bottom of the cab and the paint the front of the cab in the engine compartment area. Then I can put the cab on and start building it.
