Old 06-21-2013, 01:15 PM   #1
wibilly
wibilly's Avatar
drop , shock and panhard bar ?
droped the front 2" with spindels doing the rear with blocks 2" to 2 1/2. do I need to shorten panhard bar and relocate shock mounts? it seems to me the shocks are at to much of an angle at stock height what do those of you who know recommend thanks
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-21-2013, 07:04 PM   #2
Square_78
Square_78's Avatar
Re: drop , shock and panhard bar ?
No you do not need drop shocks or extensions or pan hard bar with 2" drop. Have a look at your rear axel. Is it pulled off to one side noticibly? Either to the drivers side or pass side? That's the only time you need a longer or shorter bar. Using spindles and lowering blocks, your shock mounts have not moved at all from factory. Drop shocks would be a waste of money and time.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-21-2013, 10:27 PM   #3
wibilly
wibilly's Avatar
Thanks square 78 , that's what I thought, nothing but ride height will change. I just might have to get after that and get that thing leveled out.
Old 06-22-2013, 02:06 AM   #4
67c10rustbuket
67c10rustbuket's Avatar
Yeah, what square said. Original length shocks are what you need with spindles/blocks. 2" in the rear should not move the rear end off enough to need a different pan hard bar. Although with 40+ year old springs they may have already sagged a bit. I say drop it then measure how far off center you axle is then decide if you need an adjustable bar. I believe most recommend an adjustable pan hard at 4" or 5"+ rear drop. BTW pics are required here
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
