![]() Join Date: Dec 2012
Header Clearance Issues
Working on my project and I've come across yet another issue. My Drivers side header has a small hole where it has come into contact with upper control arm grease fitting. The plan was to have the headers Jet hot ceramic coated. First any recommendations on correcting the clearance issue. 2nd will welding the hole effect the header.
Re: Header Clearance Issues
Pictures
I don't know what your budget is, but if it were me, I would put a different set of headers on it......
octane 1971 C10 Cheyenne - Project Truck 1971 C10 Super Cheyenne - Driver |
Honestly quick fix so u don't have to spend money just time if u have use of a torch. Mark spot to clearance add little heat hit with hammer. Cheap easy fix. Do it right then the headers can still look good and be coated.
Posted via Mobile Device |
Thats what hapened to my long tubes....hammer n heat!! For now...
On or off the motor. I would think doing it off I'm I correct?
Yup, off, maybe take a grease pen, or whatever you want to mark the area to be...modified, and then take it off...
while you're at it ,get whatever line that is on the left side of the first picture away from the headers
In the process of removing, cleaning and fresh paint on the motor and frame.
