Old 06-22-2013, 02:45 PM   #1
topsof7
steering box needs replaced
I have a 71 Cheyenne K10. The power steering fluid just dumps out through the steering box. So I figure that I need to replace it with a new or rebuild. Can anyone offer any advice on the correct process? I Don't want to screw it up. Any advice or input would be greatly appreciated.
topsof7 is offline   Reply With Quote
Old 06-22-2013, 02:56 PM   #2
SS Tim
SS Tim's Avatar
Re: steering box needs replaced
Start with the factory service and overhaul manuals. If you don't have them workable copies can be downloaded here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 06-22-2013, 03:55 PM   #3
68gmsee
Active Member
68gmsee's Avatar
If your gearbox is otherwise in good shape, I would just replace the seals. There's some good info on the web on how to do it and if you have the tools and done mechanical work before, it's not that difficult to do. Just be sure and read and follow the instructions first. I did my first seal replacement couple of years ago.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-22-2013, 07:04 PM   #4
topsof7
Thanks for the info
Old 06-22-2013, 07:00 PM   #5
kcsa75
kcsa75's Avatar
I replaced my steering box last summer. It's a straightforward parts swap, no big deal. But I would suggest purchasing a new steering box that has the rag joint already installed.
Ask me how I know. LMC was about $75 more than O'Reilly or Car Quest, but well worth it in my opinion.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 06-23-2013, 05:40 AM   #6
JointTech
JointTech's Avatar
well its nice that it comes on the gearbox from LMC. but if its $75 bucks more maybe not worth it. You can get the rag joint on rockauto for $40.
I replaced my gear box today. no big deal, 3 bolts and plan for some power steering fluid in your face.
What does suck is you cant get a rag joint locally anywhere and brothers and CPP close at noon on saturady.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-23-2013, 11:33 AM   #7
domeier
domeier's Avatar
Any idea what the rag joint is made of? (and you better not say, "rag!") Seems like you could make one fairly easy if you had a suitable material.
domeier is offline   Reply With Quote
Old 06-23-2013, 12:43 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Made of durable flexible material. You could rebuild it (some links below) but no you can't make your own -at least I wouldn't chance it. If yours is okay, you can reuse but be aware that they make different sizes and gearbox input shaft needs to match it.
http://www.classicparts.com/1967-86-.../#.Ucckx0Ao4tk
06 Trailblazer
Old 06-23-2013, 02:24 PM   #9
JointTech
JointTech's Avatar
i thought it was some fancy cluth thing, but really it looks like just a peice of rubber to stop vibration up the steering column. Im going to order a new one.
72 C20 Long Bed
Old 06-23-2013, 03:29 PM   #10
domeier
domeier's Avatar
Yeah, my rag joint is good. I kind of like saying that. Rag joint. I just wondered what the material is. Sort of the same thing as fan belts are made of?
If I was in your shoes, I'd bite the money bullet and replace the box without messing with the seals. I'd be really bummed out if I got it all back together and it started dripping.
Old 06-23-2013, 04:42 PM   #11
MidLifer
MidLifer's Avatar
I just did this with a reman box that I picked up from napa for $125. Very straightforward. Definitely flush the hell out of any rebuilt box. I did a cursory flush on mine, then drove it about 100 miles and had to flush it again. The fluid was filthy. Now that's behind me it works fine.
Also spend $20 on a Magna Pure inline filter. It will make the new box last longer.
MidLifer is offline   Reply With Quote
