Zero Rust Restoration
For this Sunday, Monday, and Tuesday I will be taking on a project to restore the bed of my 1972 c10 long bed pickup. I will describe the procedure i use, as well as the materials i use (for the more important materials, i will include links to the brand website). All of this will be completed with pics! This should be a good project and i will give you all updates of how the product is holding up after the project is finished.
Materials: 1. Orbital sander with Diablo 100 and 220 grit Sanding Disks 2. Drill with AvantiPro- Quick-Strip Disk and 3'' Cut-Off Blade Mandrel, Vermont Ameriva- Grinding Point, and Diablo- Metal Cut-Off grinding wheel 3. 1 lb 12 oz Bondo Body Filler http://bondo.com/featured/bondo-body-filler-260.html 4. 1 Qt Ospho http://www.ospho.com/ 5. 1 Qt Marine Clean http://www.por15.com/MARINE-CLEAN/productinfo/MCG/ 6. 12 oz Prep Step Powder http://raybuck.com/i-66993-12-oz-prep-step-powder.html 7. 1 Qt Black Zero Rust http://raybuck.com/i-66984-zero-rust...art-black.html 8. 1 can Crystal Coat Here are some pics of the truck now Attachment 1123704 Attachment 1123705 Attachment 1123706 Attachment 1123707 Attachment 1123708 Attachment 1123716 Attachment 1123717 Attachment 1123718 Attachment 1123719 Attachment 1123720 Attachment 1123723 Attachment 1123724 Attachment 1123725 Attachment 1123726 Attachment 1123727 Attachment 1123728 Attachment 1123729 Attachment 1123730 Attachment 1123731 Attachment 1123732
"No one ever drowned in sweat." ― United States Marine Corps "I walk slowly, but I never walk backward." ― Abraham Lincoln |
Re: Zero Rust Restoration
The links above for the pics did not work, i am now redoing them
I have a tip for cleaning and resurfacing metal.
Polycarbide disks are outstanding at removing any and all contaminates from metal on contact, it will not remove metal and most of the time you don't even need to apply pressure just the weight of the grinder is enough, only on heavy scale rust do you need to apply any pressure. Go down to Harborfreight and buy five of the 4.5" polycarbide disks and use them on a side angle grinder, it should be enough to strip the entire bed, you will have $25 in it. Here is a link http://www.harborfreight.com/4-1-2-h...eel-94017.html |
I was thinking about using a grinder, but i just didnt have the money to buy one. But, they definitely look like they would do a lot better than my dinky drill and a wire wheel
Harborfreights Heavy Duty 4.5" angle grinder is good quality it will run forever and not overheat and it just happens to be on sale for $18.99 with the coupon online just print it out and go down there, it's probably in their newspaper coupon also.
Still Learning
Looks like a cool project and you have good plan. I have been all through the rust repair. I completely restored a cab. It's huge undertaking even if you have a bunch of tools. I'm gonna follow along....
Thanks Xeen, i will look into it. But i unfortunately just coated the bed in zero rust
Time for some pics of the post power wash, post puddy, and post prep step! Sorry i forgot to take some pics before the power wash and prep step. But there was really no difference after the prep step. The power wash just got a small salt white film off of some parts.
Now for some pics of the bed with one coat of zero rust!!
Just remember that this isn't finished yet. I need to put one more coat on and i need to put on the top coat (crystal coat).
#15 |
After a day of letting this stuff dry, im seeing those inconsistencies in color in the pics (like the gray and black) are there to stay
#16 |
I used Zero Rust on my frame and some parts. I like
project: "my happy mess" |
