Old 06-28-2003, 11:54 PM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
turbocharged ebay truck
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421253494
I've never seen one of our trucks with a turbo before.
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 06-29-2003, 12:14 AM   #2
Mike76251
No wonder is has no miles...................
That is waay too much boost for street gas.
Cool engine though.
Mike76251 is offline   Reply With Quote
Old 06-29-2003, 12:26 AM   #3
2tankin79
2tankin79's Avatar
one of those sit in the garage drink a few beers, look at the engine things?
2tankin79 is offline   Reply With Quote
Old 06-29-2003, 12:30 AM   #4
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
sweet truck.
mike reeh is offline   Reply With Quote
Old 06-29-2003, 01:09 AM   #5
r0lf-
Hotwheels?
r0lf-'s Avatar
I thought carbs didnt like turbos?
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 06-29-2003, 01:57 AM   #6
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
Turbo Technology in WA had a shop truck back several years ago they did a twin turbo setup on I think (maybe it was a single) but it made close to 1000 hp and was a very easy driver the way they talked about it. http://www.turbotechnologyinc.com/ is their website in case anyone was interested. If I recall right the truck was a 76 short wide bed and was orange and tubbed rear end. I have the magazine around somewhere that had the article about it.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 06-29-2003, 01:32 PM   #7
sbc350gearhead
sbc350gearhead's Avatar
That is one of the funkiest turbo setups I have ever seen. I wonder how it can flow fuel through the turbo without condensing on the tubes and impeller?
sbc350gearhead is offline   Reply With Quote
Old 06-29-2003, 02:29 PM   #8
low 84
low 84's Avatar
Cool engine though.
hes only runnin 8.2 cr and i'm sure he has a boost controller on it. probly turn it down to 10-15 lbs for stret driving. i bet its a blast to drive once that big arse turbo spools up though
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 06-29-2003, 02:44 PM   #9
1FaastC10
1FaastC10's Avatar
that's easy. it doesnt flow fuel through the turbo. the fuel is put through the carb, and the tube from the turbo supplies compressed air. they both go down the intake to the cylinders.
1FaastC10 is offline   Reply With Quote
Old 06-29-2003, 06:32 PM   #10
Lil Greg
Anyone ever seen this one from Vortec for a carberated SBC looks like the carb sets in a box is so i guess you would'nt want any bowl leaks or vaccume leaks on you carb lol.
Lil Greg is offline   Reply With Quote
Old 06-29-2003, 06:46 PM   #11
neonlarry
neonlarry's Avatar
From reading that, I don't think he has ever run more that 14psi of boost. All he said, is that with 24psi desktop dyno said it would hmake that much power. Look at the exhaust routing too.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-29-2003, 06:52 PM   #12
sbc350gearhead
The engine is not fuel injected but rather uses a draw thru system. The carb is a 1150 dominator worked for the system that then feeds fuel and air thru the turbo then back into the intake manifold.
I based my question off of that statement in the ebay ad. The guy may not know what he is talking about. How does a draw through carb meter fuel without vacuum?
Old 06-29-2003, 07:44 PM   #13
houston6
houston6's Avatar
why?turbo uggh!i dont like it not pratical of course thats just me
is that hp rating accurate?
Scott
houston6 is offline   Reply With Quote
Old 06-29-2003, 07:53 PM   #14
Cole's 87
Cole's 87's Avatar
Pontiac used that sort of set up on their 80 or 81 turbo Trans Am with a 307cid it was a totally uprdictable set up. The way the adapter is set up when te air off the turbo goes threw the plate it causes vacume under the carb which pulls gas + air the only problem with the set up is when you let off the gas the boost has no where to go but back threw the carb which caused alot of fuel leaks. In a nut shell it was junk that is why vortec puts the whole carb in a box but the carb has to be reworked for that type of use.
Cole's 87 is offline   Reply With Quote
Old 06-29-2003, 10:09 PM   #15
1FaastC10
1FaastC10's Avatar
Mike, look at the exhaust end of the turbo. the pipe goes directly under the carb. the guy is full of it.
Old 06-29-2003, 11:54 PM   #16
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Good Idea..Poorly executed.
If I ever win the lotto...Im putting a Supra Motor and A fat Single turbo with a 6spd in the truck!! hahhaa
Like that will ever happen!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 06-30-2003, 11:09 AM   #17
PHOENIX
Damn Cottonwood folk making us look bad
Where the hell is that turbo pipe going behind the carb?
Anyone shot him an email and asked for pictures behind the carb?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-02-2003, 11:36 AM   #18
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Guys,
I've never seen a turbo setup up like this before. I'm getting ready to install a turbo on my diesel, so that's different, but all turbos are the same in this regard:
The suction side of the turbo is the center part facing the front of the engine. The output side of the boost is on the top. The exhaust is on the second turbine, towards the back of the motor. That means this particular setup in this truck is sucking air and fuel from beneath the carb, and then blowing it all back out of the turbo and back into the engine. I don't know where it is forcing it in at, perhaps in the rear of the intake manifold. I can't see where the pipe is connected to behind the carb.
I would imagine that the carb is setting on the air intake in a way that the fuel and air are bypassing the intake manifold, and rather is going directly into the turbo. The turbo is then forcing it back into the intake. It's setup just like a supercharger, with the blower between the intake manifold and carb. However, I didn't know a turbo could work that way.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
