57 looking for a decent 4 bar setup
my 57 has 2nd gen frontend.PO flipped rear camaro axle and it is sitting on frame, not sure what to do ..(BUDGET TIGHT).I have a little less than 1 inch of travel..I was looking onto a 4 bar system.. seems one for my truck is around 1500.00..i see universal one for 300-500 range..I was going to flip the shackles..but that will raise it too high..any suggestions???
Re: 57 looking for a decent 4 bar setup
Is it C-Notch for axle flip, if it is than try and look at air assited bags that go on the leaf springs this way you can raise and still bring it down at events. The one I have will raise the vehicle total 6 inches. This way you can save for a good four bar kit.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
I did not even think of that ..I have a buddy who has a kit with compressor and everything...Thanks..BTW nice hog...I have a roadking but since this truck I have not been riding too much....take care
I was at a friend's gas station the other day and he was installing a set of Firestone air assist bags on a late model pickup and the setup looked pretty interesting for doing just that.
I am not bagging my truck but want to maintain a specific static ride height no matter if I am empty or if I have our bags, cooler and lawn chairs in the back headed out on a trip or if I get my teardrop trailer done and tow it. the overload bag setup seems to be the way to go.
![]() Join Date: May 2012
I used the nolimit fat bar setup.
I would skip the C notch and go straight to a step notch from Paul Hortons. Can't beat the price and you get to determine how much travel you want. Probably not much more work than a properly reinforced c notch.
![]() Join Date: Jun 2011
Cheap????? looks like 10 bucks worth of steel and you have to build it your self.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
I bout a 4 link kit from summit and put it inside the frame. It was not very difficult and I can run a 18" wide tire. I only had to do a small c notch on the frame for clearnce.
![]() ![]() its plenty low and I never bottom out. Probably have $550 in the whole set up ncluding the rear end.....not the tires and wheels
#9 | |
Your telling 1adam12 to step over dollars to pick up penny's. If you laid out $230 on the 4 bar that means you spent less than 320 on coilovers, disc brake rotors, calipers, pads, lines, hardware AND a rearend. Your project is cool but lets be realistic, thats a bro deal only even on used beat up parts. ![]() |
#10 | |
i agree with buggy.
maybe $10 was a slight exaggeration ($10 over priced in my shop) but i am a firm believer in diy. motor mounts, trans x-members and c-notches are the easy fruit to be picked you save a lot of money and a whole lot more time fabricating the easy stuff i have a similar set up, 3rd gen rearend with flipped axle if your on a tight budget the easiest thing is to c-notch your frame i did a 3'' notch and it should have been 4 or 5'' but much over 3 and you have to modify your bed wood to clear the rearend and notch i bought the firestone helper bags for my truck, there was no way to make them work, just no room to install them i ended up with old school air shocks and never hit my bump stops any more ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
What air shocks did you end up using??
That might be a better way to thanks!! Posted via Mobile Device |
Got any pics of your frame to axle clearance, or a dimension on the distance? With a full tank of gas would be best. If your literally laying the frame on the axle, just helper bags ain't gonna cut it.
#15 |
i agree with sqrints, if it was that easy, everyone would do it
![]() you'll still need to c-notch the frame
