Pontiac engine in a C10
Hey guys,
As you may know, i'm putting a pretty stout Oldsmobile 455 in my 86. I have an opportunity to pick up a 461 stroker Pontiac built from a 400 block. Should be in the 500HP range with about the same torque, it's pretty badass... Has anyone ever put a Pontiac 400 or bigger in their truck? ![]() ![]() If so, got any pics or tips? Kind regards
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Re: Pontiac engine in a C10
I know i'd like to find an older Olds 350 Rocket ... That block is the one GM converted to make the diesel trucks.
#3 | |
Oh yeah, get you an olds 350 DX block. can get them pretty easy, can build a hell of a motor with one of those blocks. The 455 Olds is bad ass too. I can't wait for mine to be done.
I'd hurt myself with a 455 rocket (just like the police drive) Or a good 400 olds motor my folks had in their 79' firebird.
Also i'm a bit of a noob but found why the SB 400's are tough to find... seems they used to stroke them to 383 and use the daylights out of them. Of course i may have learned to drive in the 82 but the drivers ed car at my school was a modern front wheel drive ford taurus |
#5 | |
I had a 77 c-20 crewcab with a 400 pontiac a few years ago. I didn't put it in, but it looked like it came from the factory that way. whoever did it,did a clean swap, and it ran very good too. about like a big block chevy on the gas useage though. Thanks for your service to our country
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
#7 | |
Not being familiar with pontiac motors, was/is there something about them that made it easier to drop into the squares? Over the years I've come across more than one pontiac powered square in the wrecking yards.
#9 | |
All GM engines use the rear sump in those years so it wouldn't be that hard if you had one lying around. |
