07-03-2013, 08:48 AM | #1 |
Smoke from one side of exhaust
I have true dual exhaust on this 1987 chevrolet truck. The drivers side tailpipe smokes. Any ideas on how i would stop it? If you give me an answer like 'check this' could you also explain on how to 'check' what. You are talking about. Thanks! Any info is greatly appreciated!
Posted via Mobile Device |
07-03-2013, 09:19 AM | #2 |
Re: Smoke from one side of exhaust
Could Be:
Bad valve stem seals on that bank Broke ring on that bank Clogged oil return on that bank I would not worry until it fouls a plug or consumes more than one quart every 3000 miles. |
07-03-2013, 10:18 AM | #3 | |
07-03-2013, 10:26 AM | #4 |
The smoke is white. It is not the thickest smoke, but after a little drive around the block it gets thicker
07-03-2013, 11:05 AM | #5 |
'White' smoke from one exhaust bank typically means moisture in the combustion chamber which means failed head gasket or leaking intake gasket @ one of the cooling ports.
07-03-2013, 11:28 AM | #6 |
Turbo 350??? Could be sucking trans fluid through modultor valve also....
07-03-2013, 11:35 AM | #7 |
Ahh... Very true as well.
07-03-2013, 04:01 PM | #8 |
07-03-2013, 04:21 PM | #9 |
The modulator on the side of the trans can go bad & allows trans fluid to get pulled up into the motor under certain loads causing one heck of a smoke show. Usually when it occurs, the trans doesn't shift 'right' either.
07-03-2013, 12:36 PM | #10 |
blown head gasket or cracked head my guess, especially being on drivers side....pull #1 cyl spark plug and take a look at it
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
07-03-2013, 01:27 PM | #11 |
I'd start by labeling plug wire addresses.
Then pull plugs 1,3,5 and 7; label each plug address w/ sharpie. A a pic of the plug's business ends would be nice. Variance of color and deposits may produce suspects. |
07-03-2013, 03:28 PM | #12 |
Just here to tinker
Compression test. That will help narrow it down if the plugs aren't obvious.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
07-05-2013, 12:23 PM | #13 |
Re potential bad head gasket, if you look in your radiator, do you see any whisps of black/brown/rusty fluid? If you do (and have had solid green in the past) you probably have a head gasket that is starting to fail. Took two years before mine finally let go, but I finally had an answer to where that rusty colored stuff was coming from.
Alex. |
07-13-2013, 04:53 AM | #14 |
pulled spark plug 1. ran a compression test. 0. nothing. the gauge wont even move. but what is weird is i ran a vacuum tester on the spark plug 1 and it showed compression through that, but after getting ahold of a compression tester it shows nothing. what does that mean? 3 and 5 are at 100.5 or so.. what does this mean? havent got too the others yet. taking a break. will check all and update the thread. thanks for the help!
07-13-2013, 08:36 AM | #15 |
You could apply compressed air to #1 and see if air escapes through ex pipe (stuck ex valve), dip stick tube (possible ring/piston failure), etc for clue.
07-13-2013, 04:39 PM | #16 |
Ok i will try that. Any others that had this happen?
07-13-2013, 04:41 PM | #17 |
The driver side is
1- 0 3- 100.5 5-100.5 7- 115 Passenger.. 2-0 4-125 6-130 8-145 Posted via Mobile Device |
07-16-2013, 07:41 PM | #18 |
nobody has an answer to this?
07-16-2013, 08:20 PM | #19 |
Did you pull vc to see if valves stuck open?
07-16-2013, 08:32 PM | #20 |
What do you mean by vc. I have not tried to see if a valve was stuck, no. How would i do this
07-17-2013, 08:12 AM | #21 |
vc = valve cover.
07-17-2013, 11:28 AM | #22 | |
I've seen severely worn rings/cylinder produce 60 psi compression. Haven't had the pleasure to see compression for broken rings/pistons. With 0 psi compression the culprit should be easy to find. |
07-17-2013, 01:21 PM | #23 |
Rockers way out of adjustment or worn out cam........
07-17-2013, 01:51 PM | #24 |
To apply air to cylinder, I welded compressed air quick disconnect to gutted spark plug.
