How do you clean the Cab trim?
Can you clean the cab trim to where it doesn't look old and dull? I am getting my truck painted next week and like the trim but don't want to put dull trim on fresh paint.
Posted via Mobile Device Posted via Mobile Device
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
Re: How do you clean the Cab trim?
Mothers Aluminum polish? i used it with a rag on my emblems and it worked good.
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() |
#3 | |
It is anodized, there really is not much that can be done. The anodizing has to be removed to get to the aluminum underneath, but then you have to deal with polishing it....and keeping up with it afterward. Unprotected aluminum oxidizes very quickly.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
instantly even.
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Your best bet is replacing it.
Posted via Mobile Device |
I tried polishing it out and it still looks about the same. Do you think the paint shop could paint it silver when they paint my truck or will paint not stick to it?
I rub mine down with wd40 and very light scotch brite when I wash it, keeps it shiny for a little while.
#8 | |
When they are wet they look great. They tend to look bad when dry so I wonder if clear powder coating would make these look wet all the time. It would definitely be cheaper than trying to find new GM parts.
Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
#10 | |
![]() Join Date: Sep 2009
You'll have to sand, polish and clear it. A good half days work.
Experience is something you gain when you didn't get what you wanted in the first place. No great defeat was ever just possible in the beginning. |
![]() Join Date: Oct 2011
Try some good 'ol Neverdull. Used to do that on mine every wash.... Ended up replacing it when I had the truck painted.
Please don't go anywhere near your truck with WD40 if you are taking it to get painted. The body shop will hate you for it. WD40 and new paint do not get along well at all.
![]() 1985 C10 2004 Avalanche |
![]() Join Date: Jun 2010
Somewhere on this forum someone mentioned that you can strip the top coat. Then you will have to polish it and keep doing it every now and again since the top coat is no longer there.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#15 |
I clear coated mine when I did my resto. Looks great and stays that way. I just run a scuff pad on it to even up the finish and shot it. Did the same on my fender emblems. I dont have a picture of the cab trim but here is the emblem. I did touch up the black. My cab trim looks just as good.
#16 | |
#17 |
I just used a fine scuff pad. You can use one like you use for the dishes or get one from the paint store. Dont get to aggressive with it , it dont need to be perfect. The clear coat will cover a lot. Just try to get the finish to look even and scuff it left to right then shoot it. Try to work any dents out if there is any before you scuff.
#18 | |
X2 on this. Don't do it....
#19 |
![]() Join Date: Oct 2009
Scotchbrite it or polish it, then have them clear powdercoated. They will look great for years.
