Old 07-08-2013, 10:32 AM   #1
racerx8413
Porterbuilt Dropmember and steering linkage
For those of you that have the rack and pinion on the newer coilover/touring crossmembers, how/where did you mount the support bearing for the steering shaft?
The newer dropmembers with rack and pinion - the steering shaft feeds underneath the drivers side dropmember support brace - so the angle of attack to the steering shaft is pretty severe - requiring the use of the 3rd knuckle and a support bearing.
What I'm unsure of is, where to mount that heim joint and do i need to make a bracket of some sort? I did some googling and searching, but couldn't find what other folks have done, i guess because the coilover dropmember is a bit newer, and the rack and pinion mount is a bit closer to the cab and lower on the crossmember.
racerx8413 is offline   Reply With Quote
Old 10-05-2013, 11:41 PM   #2
cool68
Re: Porterbuilt Dropmember and steering linkage
anyone?
cool68 is offline   Reply With Quote
Old 10-06-2013, 12:27 AM   #3
racerx8413
Hey, saw your message, figured I'd post what I ended up doing,
I had a local welder build me a bracket, it works pretty well, and wherever you have the nuts spun on the heim joint, make a world of difference in clearance/binding of the joints...
very simple, just a flat rectangle piece, with another flat retancle piece welded towards the front.
my measurements were a little off, but nothing not solvable by drilling the holes in different spots (I attached the rough draft i sent him)
Old 01-25-2026, 01:47 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Anyone have any more information or install pictures of this?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-25-2026, 02:17 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Reach out to to Porterbuilt
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
