Old 07-12-2013, 01:49 PM   #1
ckato4477
how far forward to move engine?(big block swap)
How far forward from the original mounting points do i have to move the big block to clear the firewall without having to clearance it?
this is for a 72 blazer in case that mattered
ckato4477 is offline   Reply With Quote
Old 07-12-2013, 02:39 PM   #2
turp mcspray
turp mcspray's Avatar
Re: how far forward to move engine?(big block swap)
On mine, I added a th400 with the bb. The th400 to 250 adapter, moved the transfer case stick location by 1 inch. So I moved the transfer case BACK 1 inch, to keep the stick in the original location. My engine ended up being 2 inches forward from the factory v8 position. With a short water pump, a 2 wd fan shroud, and factory clutch fan setup, the fan blades are half in/half out of the shroud. Everything looks like came from GM that way!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-12-2013, 02:41 PM   #3
tjsblazer
tjsblazer's Avatar
Is you suspension factory ride height or do you have a lift. I'm curious about clearance between the engine x-member and front diff.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-12-2013, 08:39 PM   #4
ckato4477
Turp, how much clearance between your valve covers and firewall do you have? Any pictures of it?
Old 07-12-2013, 09:29 PM   #5
turp mcspray
I do have a 6" lift. I extended my cross member by 2", so I could use a large factory oil pan. (6 or 7 quart) These are original, wore out springs, but with stock height, you may not have enough clearance. Here are a few pics. Lots of firewall clearance.
Turp Mcspray
Old 07-12-2013, 09:58 PM   #6
ckato4477
Perfect thank you. 2" forward it is then.
Old 07-15-2013, 08:03 PM   #7
BLT-NT-BOT
I moved mine forward 2" also and seem to have plenty of clearance. I am also running a 6" lift, so the pan to axle clearance wasnt a problem.
BLT-NT-BOT is offline   Reply With Quote
