Old 07-17-2013, 04:05 PM   #1
66/87chevy
Rear end swap ????
Any info out there on what rear end would be a direct swap to go in my new to me 85 c10.
It has the stock 10 bolt with 2.73 gear in it now. I'd like to go to a beefier axle and a 4.10 or 4.11 gears. What is available for these trucks?
66/87chevy is offline   Reply With Quote
Old 07-17-2013, 04:13 PM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: Rear end swap ????
well you could do a 12 bolt, or go with a ford 9' rear end, or just do a gear swap.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 07-17-2013, 04:33 PM   #3
Ziegelsteinfaust
The 12 bolt is not much of an improvement over a 8.5 10 bolt that you have.
4.11 gears are $250ish from most suppliers, and while at it I would rebuild my rear end. Then toss in some better axles, and posi. So you be good to go for quite a bit of HP/TQ.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-17-2013, 04:56 PM   #4
66/87chevy
Yeah I was thinking of doing a gear swap and replacing everything that is wore. But I was kind of hoping I could score on a complete rear end off of a different vehicle that already had the 4.11 posi The local wrench-N-Go has a few newer rear ends to chose from but I'm not sure if I could just swap them with out any major fabrication.
Old 07-17-2013, 09:33 PM   #5
Blackpony
Blackpony's Avatar
If you are handy with tools and setting up a set of gears, there is a killer deal on ebay with bearings, limited slip and gears. let me see if I can find it again.
here you go. They also offer this with a 30 spline limited slip unit
http://www.ebay.com/itm/GM-8-5-10-Bo...cfda23&vxp=mtr
Blackpony is offline   Reply With Quote
Old 07-17-2013, 10:07 PM   #6
66/87chevy
That is a pretty good, but Dang!!!! That's darn near what I paid for my 85 roller.
I will look into what tools I'd need, and see if I think it's something I can do my self.
Thanks for the link.
Old 07-19-2013, 11:12 AM   #7
LONGHAIR
With-out previous experience, plain and simple....no.
And if the price of the parts gives you sticker shock, you are better-off with swapping the entire axle housing assembly. Just be aware that the later model axles do not have a "true" posi-traction unit. They are equipped with the G-80 (Gov-loc), not the strongest piece out there. They are prone to failure, especially with higher horsepower, bigger tires, or aggressive driving.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-19-2013, 07:55 PM   #8
low82c10
So it's better to replace inside parts or find something in junk yard.
low82c10 is offline   Reply With Quote
Old 07-20-2013, 09:31 AM   #9
SCOTI
SCOTI's Avatar
Its better to replace the internals & build to spec.... A junkyard/craigslist score is usually a gamble unless you're @ the right place & time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-20-2013, 10:58 AM   #10
LONGHAIR
"Pay a pro" to replace internal parts, not a DIY job.
Old 07-17-2013, 10:50 PM   #11
franken
If you've got self serve scrap yards, I'd expect you have a great selection.
Measure or research the wheel bolt pattern.
Measure from close to the ubolt outside of the spring to the same place on the other side on the inside of the spring. This should be the center to center perch difference.
Measure the width of the spring.
Measure the outside of the spring to the wheel mount surface. Or measure directly.
Add the perch measurement, spring width plus 2X the outside of the spring to WMS for WMS-WMS.
Go the the scrapyard and find rears with that bolt pattern, with same perch center to center and close WMS.
I explain things poorly, so, sorry.
Old 07-19-2013, 05:09 AM   #12
wraprail
wraprail's Avatar
1979 Ford Torino uses a 9inch same width & bolt pattern (5x5) as our trucks. You need to remove all the brackets and crap from it and weld some leaf spring pads on it.
Lincoln Mark V has same rear end but with disc brakes.
wraprail is offline   Reply With Quote
Old 07-19-2013, 10:49 AM   #13
66/87chevy
Thanks for the info, good to know.....
Old 07-20-2013, 10:14 AM   #14
Sodell
Sodell's Avatar
3.73's are pretty abundant for the C10, not 4.11 but closer to what you are looking for.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-20-2013, 01:04 PM   #15
esbstuff
Go with the 12 as its almost a bolt in. Lots of them are available. VERY big interchange if you can DIY almost anything. Just make sure you pickup a 5 luger as your 10 bolt axles would not work in the 12
If you want 4.10's you will almost have to buy new gears as they are a rare find stock.
I personally like 3.42's in a driver a good all around gear. Gives you pull as needed, but still fuel friendly. 3.73's 4.10's ok as a driver IF you have OD trans.
But everything depends on motor/trans/primary use of the truck...
$250 should get you a nice 12 easily.
esbstuff is offline   Reply With Quote
Old 07-20-2013, 01:13 PM   #16
low82c10
i just put a 5.3 in my square, it seems like its at a high RPM on the highway, i havent checked what gears i have but would be a good gear to go with? its got the 4l60e and i want to be able to just cruse at about 2000rpm at about 75-80 like it does in the stock truck.
Old 07-20-2013, 04:48 PM   #17
LONGHAIR
Uh, what gear was in the truck it came from?
Old 07-20-2013, 06:46 PM   #18
low82c10
im sure stock gears, the motor came out of a 2004 tahoe
Old 07-20-2013, 09:32 PM   #19
INSIDIOUS '86
INSIDIOUS '86's Avatar
Why would anyone bother with a power robbing ford 9 in a truck unless you got 800+hp?
Suburbans from what I have seen are typically lower geared and several get beaten and scrapped before any real miles get into them which is nice. At least up here that's the case.
Later ten bolts have bigger axles and are only marginally weaker than a car 12 bolt. Which if turbo gnx guys can turn 9s with them with bolt ins its good enough for me
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-22-2013, 06:59 PM   #20
wraprail
wraprail's Avatar
Not sure what you mean dude. Ford 9 inch is used in more swaps, more often then any other rear end by far. The aftermarket makes more products. Everything from golf carts to high end race cars use them.
What do you know that everyone else has missed?
Old 07-22-2013, 11:49 PM   #21
Blackpony
Blackpony's Avatar
I think he is saying that a ford 9 inch isn't always the best answer. You can build a 10 bolt to hold great power with less parasitic loss for the same or less money.
Old 07-23-2013, 07:12 AM   #22
INSIDIOUS '86
^ exactly. That and it's gm and a direct bolt in. Unless you need a niner why bother? Kinda how I think. But again we don't exactly know the intentions purpose or use exactly of the OP
Old 07-23-2013, 11:18 AM   #23
66/87chevy
My 85 c10 is going to have a mild built BB with a th350 behind it.... This is NOT a truck that I will be taking road trips with. With that being said I want this truck to be able to go from 0-100mph as quick as possible. That's why I'm thinking of going with 4.11 gears.
Old 07-27-2013, 09:59 PM   #24
INSIDIOUS '86
Depending on tire size 100mph may be all you get too haha. My 3:73s with 26" tires gets me to 115mph at 6krpm. A c clip eliminator and 30 spline axles with a t/a bearing girdle and differential of choice will handle 600hp reliably and when the tubes are welded do fine under the trans take and 700hp turbo gnx cars nice thing is the 8.5 ten can do alot and it's already under almost every truck.
Want to get to 100 really quick gears -weight+hp makes that happen quick haha
Old 07-23-2013, 12:11 PM   #25
manimal
manimal's Avatar
The ONLY advantages a 9" has(other than pinion strength) over a GM rear axle is you can change gear ratios VERY quickly.(1hr if you're slow). Have your highway gears in one chunk,and your street/racing gears in another. simple as that.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
