Old 07-19-2013, 10:28 AM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
Drop
I just have a quick question fellas!
I'm thinking of doing the cheap and inexpensive drop for my truck and cut my coils, my question is do I need to take the coil off or can I leave it on the truck and do it?
I'm going for a 3/5 drop just for the time being still fighting the decision between bags or a nice low stance.
All advice will be greatly appreciated!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 07-19-2013, 10:35 AM   #2
chris1htx
Re: Drop
for safety reasons i would take the coil off. it's going to be under a lot of pressure.
chris1htx is offline   Reply With Quote
Old 07-19-2013, 10:39 AM   #3
77ChevySharkBite
Re: Drop
Okay, is there an easy way to get it off?
Korwin
Old 07-19-2013, 10:40 AM   #4
IwantaK5
Re: Drop
If there is a way to cut the spring with the coil in, it would probably be easier in the long run just to take it out. It it were my truck i would just get some drop coils and not bother with cutting. If you want lowered and performance cutting wont give you that. It will just make it low and bouncy. If you decide to do bags make sure you do not do it the cheap way. An air bag system installed poorly not only wont get you as low as you can get but the ride quality is more than horrible.
IwantaK5 is offline   Reply With Quote
Old 07-19-2013, 10:44 AM   #5
77ChevySharkBite
Re: Drop
Thanks man!
Yeah I've heard back and forth people say they have no problems with the ride when the cut coils. Its really not driven a bunch so the ride quality isn't such a issue at this moment.
Yeah I've already decided if I do an air bag system I'm going to go Porterbuilt Products all the way. I have a good friend of mine getting an accuair system in his lexus right now so I want to see how his is before I decide who I'm going to use for that part of the deal.
Korwin
Old 07-19-2013, 10:46 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: Drop
Disagree. Are you basing this on what someone told you, or your own experience?
I did seven or eight different trucks back in the day, all with cut coils and none with any ride complaints.
My current truck has cut coils and has been a daily driver for 27 years and 200,000 miles with no issues.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-19-2013, 10:49 AM   #7
77ChevySharkBite
Re: Drop
K
How much were y'all cutting off the coils Keith or did it just depend? I figure if I did half a coil I'd be okay to get that 3ish
Korwin
Old 07-19-2013, 10:58 AM   #8
rs74
rs74's Avatar
Re: Drop
Especially for safety concern you will have to split the ball joints from the spindles to get the springs out. Just be carefull. Like stated before they are under alot of pressure so you will want to keep a jack under the lower control arm and keep pressure on it. After the spindle is free then you can SLOWLY let down the jack to let pressure off the spring and then when all pressure is off then you should be able to pull the spring out.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-19-2013, 11:03 AM   #9
77ChevySharkBite
Re: Drop
Originally Posted by frog210 View Post
jack up the truck(maybe like 2 feet) and put a jack stands on the frame, with the frame supported, loosen the lower ball joint, dont take OFF, you can either seperate it with a pickle fork $9-$20 and maybe risk cutting the boot on the ball joint or strike the spindle where the ball joint goes thru or tap the side of the ball joint nut(the reason i said dont take it off), it should drown down a little when it broke loose
(( you might have to undo the sway bar if equipped, and shock))
put a carjack under the lower control arm and lift it to put pressure on the spring, once it starts lifting, undo the lower ball joint NOW.
Some people chain the spring to the lca, i didnt
SLOWLY SLOWLY lower the car jack, the arm will travel all the way down, if you didnt raise the truck enought it will get stuck, mine did this, but it only had a slight amount of pressure on the spring so i popped it out will a long pry bar
Hope it helps
Okay thanks man it makes perfect sense!!
Sweet thanks man!!
I defnitely want to do this as safely as possible.
Korwin
Old 07-19-2013, 11:06 AM   #10
Keith Seymore
Re: Drop
You can also drop the control arm at the vehicle center, by undoing the U bolts that hold the cross shaft.
There's a little less pressure from the spring when doing it that way.
K
1979-1986
1986 - 2019
Old 07-19-2013, 11:04 AM   #11
Keith Seymore
Re: Drop
You should go by "inches" rather than coils. The relationship is 2:1, meaning for every inch you cut the coil you'll get 2" of drop at the fender.
The drop on the truck you are looking at is roughly 3"/3".
Four inches is a nice drop, which would be 2" off the coil.
K
1979-1986
1986 - 2019
Old 07-19-2013, 11:06 AM   #12
77ChevySharkBite
Re: Drop
K
Okay so my best option would be take a tape measure and mark where 2" off the top of the coil is?
Korwin
Old 07-19-2013, 11:03 AM   #13
IwantaK5
Re: Drop
[QUOTE=Keith Seymore;6180345]Disagree. Are you basing this on what someone told you, or your own experience?
I am basing this on the experience of removing and cutting already worn out 30+ year old springs and the vehicle riding poorly. I would imagine if you cut springs that were new or not very worn it would be fine.
Old 07-19-2013, 11:05 AM   #14
Keith Seymore
Re: Drop
So it sounds like the issue is the springs are worn out, rather than the cutting.
K
1979-1986
1986 - 2019
Old 07-19-2013, 11:07 AM   #15
IwantaK5
Re: Drop
K
Yeah,the cutting didn't make the worn out springs ride any better
Old 07-19-2013, 10:53 AM   #16
frog210
Re: Drop
Hope it helps
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 07-19-2013, 11:15 AM   #17
77ChevySharkBite
Re: Drop
I'm just going to do a basic flip kit in the back with specialityretails "block" they make.
How hard is the flip kit to do or is it just a matter of unbolting and flipping the leaf springs?
Korwin
Old 07-19-2013, 11:35 AM   #18
77ChevySharkBite
Re: Drop
Thank you for everyone who has responsed and given me advice and input I greatly appreciate it!
Korwin
Old 07-19-2013, 05:58 PM   #19
MWS1994
MWS1994's Avatar
Re: Drop
I'm going to be keeping an eye on this thread . I'm thinking about doing the same to my truck.
MWS1994 is offline   Reply With Quote
Old 07-19-2013, 09:08 PM   #20
Sodell
Sodell's Avatar
Re: Drop
I just completed a drop on my truck and cut one spring. Gave me about 1.5 inches, plus a set of drop spindles. I can't really tell if it affected the ride because I replaced all the suspension components, and the shocks. I can say you will have to put some cash aside for an alignment and they will have to add some shims to the upper A-arm (more $$). You will most likely have to replace at least the lower ball joints as well. You might as well save for some drop spindles if you can, and get a suspension kit so you can go ahead and replace everything. My front end is now tight and drives like a new truck. I did a LOT of research before going with this set up and it seems to be the norm, and also works well for most. I think you may have problems if you cut more than one spring (just from others experience I have read about here and on other forums).
There are also some great videos on you tube that explain the process of taking out the springs, not hard on a 1/2 ton.
And always cut the bottom...
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 07-19-2013, 10:18 PM   #21
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Drop
My friend cut a coil off on his truck and it dropped it a good amount. I would recommend a cuttoff wheel not a torch or sawzall. And if you hit the ball joint flip the castle nut upside down first.
I wouldn't go much more than 1.5 coils cut btw.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-19-2013, 11:55 PM   #22
bluex
bluex's Avatar
Re: Drop
My truck rides the best it ever has now and I've been riding in/driving it since I was 12. Its dropped with a DJM flip out back, western chassis 2.5" spindles up front and 1 coil cut. Its not rough riding or bouncy at all. Definately cut only the bottom of the coil. As Keith said the top is a smaller diameter to properly seat in the crossmember.
Cut the coil with a thin cut off wheel on a grinder, dont use a torch. Heated springs are the ones that ride rough because that changes the spring rate when you heat it and let it cool at a different height.
Inspiration:
bluex is offline   Reply With Quote
Old 07-20-2013, 12:09 AM   #23
77ChevySharkBite
Re: Drop
That's the exact drop I'm looking for is a 5/5 but I ran into a problem I realized I had stock tires so 235/75/15 which I can't really drop a truck with those tires so I have to set aside some cash to do the drop!
Korwin
Old 07-20-2013, 02:30 AM   #24
bluex
bluex's Avatar
Re: Drop
Im running a 235/55/17 up front and a 275/60/17 out back. The front tires should be the same height as yours going off the old up a rim size down and aspect size rule? I know the rear tires are even taller but the problem will be up front. I cant run a much taller/wider tire without it rubbing...
Old 07-20-2013, 10:01 AM   #25
Sodell
Sodell's Avatar
Re: Drop
I was running the 235/75/15 on my front and had no problems.
Scott
