Old 07-22-2013, 02:11 PM   #1
mobilemechanic
More eyes are better than my 2
Just set motor in and (2000 truck 5.3) and truck manifolds don't fit and oil pan is touching center link. I'm installing into a 72 c-10. I have the cpp tubular mount kit installed.... Is this normal?
mobilemechanic is offline   Reply With Quote
Old 07-22-2013, 03:11 PM   #2
truckdude239
truckdude239's Avatar
Re: More eyes are better than my 2
i used the dirty dingo 3 inch silder moutns and installed mine all the way to the back of the mounts truck pan cleared fine but the truck manifold would not i ended up using the trailblazer ss manifolds and they cleared perfect
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-22-2013, 04:28 PM   #3
mobilemechanic
The cpp mounts I used moved motor 3 inches forward also... Don't see but one way for them to go on as far as height tho
Old 07-22-2013, 06:48 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I was going to say it souns like you're too far forward. Happened to me with ECE kit...wound up using sbc towers mounted to sbc motor mounts, bolted to a adapter plate that bolted to the motor mount area on the block. Could have used truck manifolds with slight frame trim and the stock truck oil pan worked fine on the stock cross member.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-22-2013, 08:03 PM   #5
Clyde65
Clyde65's Avatar
I couldnt use the CPP tubular mounts, I used the POL mounts here (http://www.performanceonline.com/196...RACKETS-16820/)
also used Sanderson CSLS1 headers, fit was perfect
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-22-2013, 08:53 PM   #6
68basket
clyde65. i am trying to set my 5.3 with 4l60e in my frame. I have the POL tube mounts and an ece trans cross member. Do you have any pics of your mounts setup? I am having trouble lining everything up.
68basket is offline   Reply With Quote
Old 07-23-2013, 04:52 PM   #7
mobilemechanic
I'm having problems getting picture do upload but will try again later this evening
Old 07-23-2013, 01:41 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Take a few minutes to go through some of the sticky's and larger build threads. The truck manifolds don't fit many/most of the swaps because of the "bump" on the outside and the way the dump in comparison to the position of the perches/mounts.
Same with the oil pan, the truck pan will hit or hang below the cross member on many swaps, and if you move it far enough forward to not do this, it will this come close to the center link and you'll be short on room to mount a fan depending on what rad your going to run.
The trailblazer SS manifolds are a popular header option, as are the doug thorley swap headers if you want a long tube. There are a few other option like camaro manifolds or hooker cast manifolds but some fitment of those will depend on exactly where your engine falls in the engine bay.
The oil pan can be swapped out for something like the LH8/Hot rod pan easily, as well as a few others like the ctsv or fbody pans. Lists of compatible items are throughout the sticky's and builds.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-23-2013, 05:08 PM   #9
Jon01
Jon01's Avatar
I used the cheapy Ebay mount plates on mine and the stock truck pan cleared just fine on my 05 LQ4.
TBSS Pacesetters fit just fine. Maryland Speed was the best price I found for them.
Jon01 is offline   Reply With Quote
Old 07-23-2013, 07:10 PM   #10
mobilemechanic
Found my problem... I needed to put my Cpp mounts in the big block location. Oil pan clears fine now and ordered tbss manifolds.
Old 07-23-2013, 07:40 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Jon, does your pan hang below the cross member?
It may not be an issue for some, just something to keep an eye on if you run a large drop...
...or alternately power lift the front end and panic and let off the throttle and slam the front end down...but I wouldn't know anything about doing that and blowing the shocks up.
Old 07-23-2013, 07:43 PM   #12
Jon01
Jon01's Avatar
Yeah about an inch.
I don't jump RR tracks though so it shouldn't be an issue.
The stamped steel pan on my Charger is about 8" off of the ground. THAT one you have to be careful of.
I am not concerned about this pan one bit. Cast aluminum will take quite a whack before it breaks.
