Old 07-22-2013, 11:42 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dual or single steering stabilizers w 4" lift 33" tires?
My new-to-me 72 Blazer has a 4 inch lift with 33" BFGs but is otherwise all OEM with original interior and underhood appearance. I'd like to remove the dual stabilizer setup on the tie rod and replace it with a single stabilizer to have a more OEM appearance. Does my 4"/33" combo need dual steering stabilizers or will a single stabilizer set up do the job? Thanks, Pete
Old 07-23-2013, 01:03 AM   #2
argonaut
argonaut's Avatar
Re: Dual or single steering stabilizers w 4" lift 33" tires?
If you're other components are in sound condition and the alignment geometry is set correctly I don't see why you need any "stabilizers"at all. My 66 is lifted and I run 35" tires and I don't use any.
Just my two cents.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-23-2013, 07:22 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks - the front end is tight. With this ride I want it to look original - so want to put the single stabilizer system on it as GM did when it was manufactured. I've not had a truck with a 4" lift so wasn't sure if a dual system was a definite need or not.
Old 07-23-2013, 10:49 AM   #4
dieseldawg142
dieseldawg142's Avatar
a dual s. stabilizer really comes into play when you start going past 37-38" tires. i have new tie rod, ends, pitman, drag link, etc., on some hiways that have big rig grooves, it helps the tires from hunting around or if ya hit a pothole, the wheel doesn't spin off on you. some guys put them on to help with death wobble too.
with 33's, a single is sufficent.
dieseldawg142 is offline   Reply With Quote
Old 07-23-2013, 10:55 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for the help. It's a stacked dual set-up and I don't really like the look.
Old 07-23-2013, 11:06 AM   #6
dieseldawg142
yeah, a single will tuck in nice behind the tie rod. had a stacked one before, was always smacking the bottom one
Old 08-02-2013, 10:41 PM   #7
72chevyk10
I built it
72chevyk10's Avatar
i put a duel inline on mine with 35"s primarily for looks but hey, if i blow a tire its that much more control. and it did seem to help on the rough/rutted roads around here.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 08-03-2013, 12:47 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks - I just got a black Monroe stabilizer from Monroe to swap in and have the correct 1972 tie rod bracket so all set. If anyone needs a dual stabilizer set up shoot me a PM. Appreciate all the help. Pete
