07-23-2013, 11:12 PM | #1 |
Tempurature Gauge Sensor
When the motor is up to temp (190*) in my K20, the temp gauge is barely on the 2nd line. I would like it to be up in the middle. All of our other 672 Chevy's read the same way. Is there a different sender I can run?
07-24-2013, 06:29 PM | #2 |
Re: Tempurature Gauge Sensor
Bump.
07-24-2013, 06:42 PM | #3 |
Might be just as easy to put in a new guage that works properly.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
07-25-2013, 01:16 AM | #4 |
Still plays with trucks
Maybe the needle got moved so it doesn't start in the correct spot on the dial. I have had a few like that.
Hold the spindle still with needle nose pliers and rotate the needle head so it points to the bottom end of the range scale at key on engine off. Speedometers can be off this way too if they are the kind with no limit pin at zero MPH.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-25-2013, 03:50 AM | #5 |
Is your sensor in the stock location? did you try a new one yet? I'd be doing that before trying to move a needle with a pair of pliers being as ALL of your chevy's are like that...
Mine is in the wrong location because i don't have stock heads and don't know what will work so i put my sensor in the water pump, it reads low as its reading the temp after it leaves the radiator. I'm still working on a solution.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-25-2013, 03:14 PM | #6 |
I guess I should have all 3 chevy's. They are all in the head. I have put two different brands in and they read the same.
07-25-2013, 04:13 PM | #7 |
Have you changed the wiring harness? If you did any changed i'd post the question in the electrical folder and see if someone like Vettefast can help.
