07-02-2003, 10:16 AM | #1 |
one wire alternator...
The alternator on my truck went bad. Thinking about going to a one wire. What alternators have you guys used and where did you get them? Thanks...
07-02-2003, 10:52 AM | #2 |
I bought a one wire at a local parts store because I didn't have time to wait for a mail order. I was one of the best things I have put on my Blazer. No more problems and I they are easy to hook up due to the one wire. Oh, I think mine was a CSI brand.
This is only my opinion and it is subject to change. 70 GMC Short box stepside Blown 388 Stroker 72 K/5 Blazer 350/SM465/205 |
07-02-2003, 10:59 AM | #3 |
Half a bubble off!
Just use the standard GM Delco late model internally regulated alternator, that's all you need. If you are interested, I have the adaptor plug that makes the changeover very easy, PM me if interested.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
07-03-2003, 03:49 AM | #4 |
excellent info on swapping alternators on http:/www.madelectrical.com check it out you may change your mind
07-03-2003, 04:31 AM | #5 |
I finally got an avatar
i got one from a late 80s(??????) Buick from the local Napa. i just had the parts guy go through the books and found the highest amperage one he could find. It ended up being a 95 amp, and I didn't have to pay the extra money for those high amp ones. it's not a one wire, but hooking it up isn't hard at all.
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S |
07-03-2003, 04:38 AM | #6 |
I bought and am using a one wire alternator. I have been running it now for a couple of years and love it, no worries about additional wiring failures, and makes for a very simple clean install and look.
Hence, On the other hand, if you have alternator bracket problems or a single belt running fan, alt, water pump with a factory a/c equipped cooling fan, you may get startup squeal, other than than, DO IT. |
07-03-2003, 07:05 AM | #7 | |
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
07-03-2003, 10:46 AM | #8 |
Thats the Hillbilly way
I got one from here They also have a Chrome one http://www.4alterstart.com/pages/sto...irealternators
http://www.4alterstart.com/pages/sto...putalternators
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 07-03-2003 at 10:48 AM. |
07-03-2003, 12:50 PM | #9 |
I put in the Autozone 104 amp special. It is for a mid-eighties Olds Toronado #DL-7294 (12-SI alternator) and rewired the truck. Direct bolt-in and no more problems...Alot cheaper than the "one-wire" units. Besides, it has a lifetime warranty and can be had from coast to coast if it ever fails. See if you one-wire guys can have that peace of mind. I just feel that the later model internally-regulated ones are the way to go.
07-03-2003, 02:03 PM | #10 |
I got mine from Summit
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
07-03-2003, 04:32 PM | #11 |
Alright now I am confussed my truck 68 has the stock externally regulated alternator. So the single wire is internally regulated is the others mentioned on here also internally regulated? I really need more amps than the stock one I am sure. I am adding FI and electric fan stereo .... So what am I missing? I know this has been talked about on here but without the search it is hard to find.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-03-2003, 05:38 PM | #12 |
Dave, if you want something that will confuse you even more(I know I am VERY confused about this), there are some 3 wire alternators that are internally regulated. If someone can explain that one to me I would appreciate it.
07-03-2003, 05:39 PM | #13 |
By the way....thanks for all the replies on this thread. It has helped me alot.
07-03-2003, 05:46 PM | #14 |
Alex, it is a very easy modification to the existing system. The newer alternators are internally regulated so you must take your external regulator out of the system. I have the instructions if you like.
07-03-2003, 08:08 PM | #15 |
Yes please. The instructions would be greatly appreciated.
07-04-2003, 07:36 AM | #16 |
I put a Power Master in mine. It is an 80 amp at idle and 140 at higher rpm. I needed this much amperage due to my dual electric fans and electric fuel pump.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
07-04-2003, 07:52 AM | #17 |
I would be interested as well.
72 cheyenne super |
07-04-2003, 11:18 AM | #18 |
I used a Stock replacement highoutput from alterstart
07-04-2003, 02:41 PM | #19 |
Half a bubble off!
To change to the newer style, internally regulated alternator, all you need is the alternator, the 2 items in the following pic, and 30 minutes or less of your time. This is a very easy upgrade if you have the right parts, I used this on my truck 3 years ago, and have never had a problem, I highly reccomend it. This plug wires into your existing alt. harness, and the jump wire is used in the plug off of the old voltage reg. It is easy, quick, and a worthwhile upgrade.
07-04-2003, 03:19 PM | #20 |
Just tell the parts guy ya got some air con. Then you'll get a nice big amper one! To run your amps of coarse!LOL
07-06-2003, 05:58 PM | #21 |
if you guys would check out the link i posted for madelectrical i think it would answer your questions. good info there.
07-07-2003, 06:24 PM | #22 |
Hey LB,
are those alt. adaptors available at any local parts stores?
1972 chevy k10 4x4 longbed 4-inch lift, 3.73 front/rears, frame off nearly complete 1972 chevy k10 4x4 longbed parts truck, known as the "ugly green machine" 1990 GMC 3/4 shortbed ext cab Always in need of 67-72 parts in central ks. |
