Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-24-2013, 03:27 PM   #1
ckato4477
Project Fat Amy
So this project is a 72 blazer i picked up for $400 with a title and no front clip or drivetrain. It looked like this:
ckato4477 is offline   Reply With Quote
Old 07-24-2013, 03:34 PM   #2
ckato4477
Re: Project Fat Amy
The body is a little rough and so is the frame so i'll be doing a lot of patching and rust repair. I have big plans for this thing that i haven't seen done before. I've decided on a 67 front clip, and the drivetrain will be 8.1 vortec, gear splitter made to go in front of an sm465 but adapted to the front of an NV4500, np205(twin sticked), dana 60 front, 14 bolt rear with disc brakes. 52" springs up front and 56" out back. cross over steering(hi steering though).
I want it to look purdy on the street and with decent gas mileage and be a beast off road.
Old 07-24-2013, 03:45 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Re: Project Fat Amy
Looks like you got a big project!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-24-2013, 03:45 PM   #4
ckato4477
Re: Project Fat Amy
I still have the option of running the gear splitter/sm465/np205 if i want it:
I completely rebuilt the axles and set 5.13 gears in both. also there's the 37" rubber you see attached to them.:
I got the frame out from under it and it needs all new mounting bolts and bushings(go figure):
and here is the frame mostly stripped:
Old 07-24-2013, 03:50 PM   #5
ckato4477
Re: Project Fat Amy
plans for the frame are:
strip it
remove all the random little brackets i don't need
remove the engine crossmember and replace it with the DIY4x piece
remove the front and rear spring mounts/perches and replace with DIY4x stuff
cut off the front frame horns and replace with a pair that are in better shape
send it off to get sand blasted and primed
box the frame
then mock up the drivetrain and make a crossmember for the transmission
Old 07-24-2013, 03:56 PM   #6
ckato4477
Re: Project Fat Amy
this truck is my inspiration(minus the decals on the side):
Old 07-25-2013, 09:39 AM   #7
mtully79
mtully79's Avatar
Re: Project Fat Amy
My wife's name is Amy...haha! Subscribed, looks like it's gonna be a fun build!
mtully79 is offline   Reply With Quote
Old 07-25-2013, 09:52 AM   #8
ckato4477
Re: Project Fat Amy
Hahaha well my wife named it after a character from the movie Pitch Perfect.....she calls herself "fat amy"
Old 07-30-2013, 08:42 PM   #9
ckato4477
Re: Project Fat Amy
got a little work done this weekend. I got the firewall stripped and painted using the KBS coatings system:
first I wire wheeled the whole thing and some of the rust I couldn't get out(PITA)
then I sprayed on the Rust Blast stuff which worked okay but not great. I seemed like it lifted the rust a bit so I could hit it with the wire wheel and get more rust out. It really isn't anything magical by itself at removing rust but it helped the process.
this is what it looked like after rinsing off the rust blast. it left a nice coat of zinc
then I used the Rust Seal to paint over it
Old 07-30-2013, 08:47 PM   #10
ckato4477
Re: Project Fat Amy
I'll be installing a vintage air system later so i'm not worried about patching the rust holes by the heater box yet.
......and I got the frame mostly stripped too, I just have one more cross member left to remove and to unbolt the transmission crossmember so I can send it off to get blasted. then it will be ready for me to box it and put it stronger and better placed crossmembers:
Old 07-31-2013, 02:14 PM   #11
ckato4477
Re: Project Fat Amy
got the last crossmember out and tacked on a few pieces just to hold it all together. it goes to the sand blaster tomorrow:
Old 08-05-2013, 10:10 PM   #12
ckato4477
Re: Project Fat Amy
I got in a nice package from DIY4x with the rear shackle flip and engine crossmember with all greasable bolts for every pivot point. Also i got the frame back from being blasted, now i can start boxing it and putting on the new brackets and crossmembers:
.....So i mentioned on another thread that i wanted to graft a shortbed onto the blazer so i could get an extra 6"ish of wheelbase, so i started the chop.
Old 08-06-2013, 03:35 PM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Project Fat Amy
subscribed and watching here now...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-06-2013, 03:37 PM   #14
Effeckt
Effeckt's Avatar
Re: Project Fat Amy
Am as well. Interested in seeing the end result for sure.
My 1972 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=399719
Effeckt is offline   Reply With Quote
Old 08-06-2013, 04:43 PM   #15
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: Project Fat Amy
yeppers
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 08-06-2013, 04:57 PM   #16
ckato4477
Re: Project Fat Amy
anyone know where i can find a nice shape shortbed around tennessee/kentucky?
Old 08-06-2013, 05:29 PM   #17
Benji
Re: Project Fat Amy
Seen one on craigslist in Cincinnati, Ohio no pic though for 800. Unless thats too far for ya
Benji is offline   Reply With Quote
Old 08-06-2013, 06:47 PM   #18
ckato4477
Re: Project Fat Amy
Its a little far.I'm in clarksville TN. Pretty much right on the border of Kentucky and Tennessee
Old 08-06-2013, 08:07 PM   #19
ckato4477
Re: Project Fat Amy
I think i might just buy new bedsides and bed floorpan. Itll save me the hassle of finding a decent bed, then doing rust removal and extra body work. Like not having to shave the side marker lights and cutting holes for the fuel filler, and of course smoothing everything out. Im going have a hidden fuel filler behind the license plate.
Old 08-07-2013, 07:36 AM   #20
ckato4477
Re: Project Fat Amy
When you buy new bedsides do they come with the inner bedside attache or is it just the skin?
Old 08-07-2013, 09:04 AM   #21
NPilot1975
NPilot1975's Avatar
Re: Project Fat Amy
They come as a complete bedside with any and out metal.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 08-07-2013, 09:10 AM   #22
ckato4477
Re: Project Fat Amy
Originally Posted by NPilot1975 View Post
.... with any and out metal.
Old 08-07-2013, 11:01 AM   #23
Ol Blue K20
Re: Project Fat Amy
I think he meant inner and outer metal.......
Dale
Old 08-07-2013, 11:04 AM   #24
NPilot1975
NPilot1975's Avatar
Re: Project Fat Amy
Yes, little too early and didn't retread before submit. Meant to put inner and outer. Lol
Old 08-07-2013, 12:19 PM   #25
Dale99
Re: Project Fat Amy
I can confirm that as I have one sitting in my garage at the moment.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
