question about white cabs.
Did all white cabs have belt molding? Looking to see anyc/10 with white cab and no belt, any year. thanx kevmac
Posted via Mobile Device |
Re: question about white cabs.
Kev,
I can't say for sure, but I don't believe I have seen one that doesn't have the trim separating the two colors. I just sprayed my roof white and bought a belt mldg from a board member. The line came out so straight I'm toying with the idea of not using the trim when I'm done. I'll just have to see how it looks and I feel about it when I'm closer to being finished with the build. Heck, it seems my plans change about things on this truck day to day, even hour to hour at times. That's just the way it goes with this hobby! Danny |
I'll emit the bat signal for SSTim, and he can clear this up lol
My white '69 c/10, L-6, no P/s, no P/b, came without cab divider trim.
![]() ![]() It ain't yours, if you didn't build it! |
I have seen original trucks with molding and without.
#6 | |
As you can see in the picture below there were three basic molding groups the BX2 Lower Bodyside molding, the B85 Upper Bodyside (belt) Molding and the D99 Paint Divider Molding. Since this question appears to be about two-tone trucks we will only address the D99 at this point. Any factory two-tone truck will have a white, cream (67-68) or alternate color (custom two-tone) for the roof. The cab back will have the D99 paint divider trim. That code however, only shows up on a build sheet as D99 TWO TONE PAINT most of the time. The two-tone paint is indicated on the SPID solely by the paint code on most trucks with the cab trim implied. So an original truck should have the molding or remains of the weld studs for the clips and a two tone paint code. As a note solid color trucks should not have the cab divider trim. This is most often seen on repaints that did not retain the original white/contrasting roof.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 07-27-2013 at 01:38 PM. |
thanx tim, i was referring to solid color trucks with white cabs. some i see with paint divider, some without. some with lower only, some with upper and lower but no white stripe between. just clarifying.
OK, But to clarify the color schemes need to be broken down.
Solid Paint. any single color, no moldings required. Conventional Two-Tone. white roof/body color, includes D99 divider molding. Special Two-Tone. white roof/body color/white rockers, has white rockers in addition to the roof, includes D99 divider molding and requires BX2 lower bodyside moldings. Deluxe Two-Tone. white roof/body color/white side/body color, has white bodyside panels in addition to the roof, includes D99 divider trim and requires B85 upper bodyside moldings and BX2 lower bodyside moldings. Custom Two-Tone. select contrasting roof color /body color, these were identical to the conventional two-tone but without white. blue/blue and green/green were examples often seen as was the much less common black/red orange, includes D99 divider trim. Remember solid trucks could be had without any molding (depending on trim level) D99 divider molding came only on two-tone ordered trucks. Upper and lower bodyside moldings were available on any trim level (within years and body styles offered) without two-tone paint. Thus side trim does not equate to a two-tone.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
That about wraps it up right there. One quick note, the upper door, always white also? I've seen some body color all the way around next to the white cab. Thought it looked odd. Maybe not. Man, what did I do before the Internet came along.
#10 | |
![]() ![]() Join Date: Jul 2002
kevmac
not sure if both of these were factory withou the trim or not, but at least it will give you an idea of what you were asking
I have a radical idea!
Below is correct way white roofs were painted on '67 models only.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#13 | |
This clears up a lot. Thanx every one who chimed in. With all the repaints out there it gets confusing.
#15 |
Is it OK to be jealous of an object? Me thinks YES. Darn nice ride there!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
