79 wheel swap
I'm wanting to do a wheel swap from a 2006 3/4 ton 4 wheel drive with stock aluminum 8 lug GM wheels to a 79 3/4 ton 4 wheel drive with steel wheels. The 06 aluminum wheel has the center cap with plastic nuts that thread on to the lug nut.
My issue is the studs. the 06 uses metric studs and I beleive the 79 to be standard thread. Has anybody done this swap? What did you do? Switch the studs or use different nuts? Where did you get them? A longer stud wouldn't hurt with the aluminum wheels. Thanks in advance! |
Re: 79 wheel swap
They make conversion nuts, that are called "conversion nuts." Theyhave standard threads on the inside, and what ever threads on the outside to do just what you want. Just google "GM conversion lug nuts."
Re: 79 wheel swap
Thanks! I was just looking through the 73-87 long bed pictures a saw a few with the wheel swap. So I knew it was possible.
Re: 79 wheel swap
Re: 79 wheel swap
Holy crap! This is perfect. I have the same truck, with the same wheels, with the same problem. Ordering the conversion lugnuts today. Thanks!
Michael - 1962 C20 LB stepside (project thread) - sold - 1963 Chevy C10 LB stepside (donor) - 1963 Chevy C10 LB Custom flatbed (project thread) - sold - 1979 K20 LB fleetside (project thread) Favorite exchange on the board so far: ol_Curt: "Jason, do you have power steering?" jason65: "No, but I lift weights." |
Re: 79 wheel swap
I went different way, and bored out the lug holes to use mag wheel nuts. I added a 1/2 spacer to make it easy, but one could get by with a 1/4 inch. In the future I plan to add the nipple caps to fill up the center.
