07-29-2013, 10:12 AM | #1 |
How to make a truck motor look good?
You go look in vettes and camaros etc and the motors look clean and pretty sweet, however when it comes to these truck motors they just look butt ugly.
So my question is for some of you 5.3 and 6.0 guys.... what have you done to make the engines eye candy? To my understanding if you use a car intake that requires alot of other changes like to accessory brackets ect. Thanks in advance. |
07-29-2013, 01:36 PM | #2 |
Re: How to make a truck motor look good?
Car intake + accy's.
I've seen some smoothed intakes where they cut all of the ribs off of them and they still looked awful. Wise man once said - you can't polish a turd. |
07-29-2013, 01:38 PM | #3 |
Put one of these on top.......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-29-2013, 02:42 PM | #4 |
07-29-2013, 04:20 PM | #5 |
The coil packs will be in the stock location. I'm using the Holley LS accessory brackets.
07-29-2013, 09:47 PM | #6 |
Here's what I did.
Just a little paint and I think it looks O.K. Kim |
07-29-2013, 10:00 PM | #7 |
I don't think it looks too bad?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
07-29-2013, 03:13 PM | #8 |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-29-2013, 03:54 PM | #9 |
That cover looks good, maybe I will have to find some for my build!
07-29-2013, 10:46 PM | #10 |
Me either
Posted via Mobile Device |
07-29-2013, 11:01 PM | #11 |
Those look really nice. Hope mine looks as nice
07-30-2013, 10:42 AM | #12 |
Rex |
07-30-2013, 10:47 AM | #13 |
07-30-2013, 03:44 PM | #14 |
Kim57 is that Pontiac metalic blue? Your paint job looks good.
07-30-2013, 11:47 PM | #15 |
Thanks for the compliment, it is a Vortec Max cover, I just ground off the letters with disc sander and then used bondo to fill and feather it out. Be sure and scuff the rest of cover and use a plastic adhesion spray before painting.
Rex |
08-16-2013, 06:59 AM | #16 |
A day late and $1 short...
This factory looking orange and black is awesome! This is the look I'd like to achieve!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
07-30-2013, 06:29 PM | #17 |
meowMEOWmeowMEOW
^^I thought that too in the first picture, but the second picture looks more gray-mica. sweet color
07-31-2013, 11:13 PM | #18 |
I'm building a whole engine cover out of aluminum since I don't care for the stock ones and with it fully covered it cleans up everything. It also allows me to go hood less.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
08-01-2013, 03:23 PM | #19 |
Boosted Member
It's still pretty ugly, but LS3 intake and F-body accessories helped. Also moved the coils.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
08-02-2013, 01:49 PM | #20 |
Still Learning
Nothing Ugly about that engine! work of art
08-01-2013, 06:03 PM | #21 |
I like that too... other than the turbo what did it take. Dont you have to have l92 heads for the ls3 intake?
08-02-2013, 10:06 AM | #22 |
Boosted Member
Yes, i have LS3 heads (rectangle port)...hence the LS3 intake. Just bolt the f-body accessories on (with an F-body balancer) and go. I made brackets to relocate the coils down by the motor mounts.
08-02-2013, 10:09 AM | #23 |
08-02-2013, 10:52 AM | #24 |
Boosted Member
The crank pulley is the balancer.
08-02-2013, 03:50 PM | #25 |
Coil relocation & nicer valve covers are a good start. Putting an aluminum intake on it is expensive but probably helps. Brackets that are a little less industrial looking would help too but I don't know whats available without going to the full car accessory setup. A standalone harness will lay out a lot cleaner / nicer than a modified factory setup. Other than that... it's an engine.
