Old 07-30-2013, 09:40 AM   #1
tr4boy
need help with 63 c-15 parking brake
Hi, folks,
the parking brake on my 63 c-15 seems to be sticking. The lever seems to ratchet and release correctly, but the brakes remain in the parked position. Any ideas where I should start checking to see what the problem is?
thanks!
tr4boy is offline   Reply With Quote
Old 07-30-2013, 10:22 AM   #2
1963c-10
1963c-10's Avatar
Re: need help with 63 c-15 parking brake
Sounds to me like the cables are not releasing at the rear brake. The cable connects to the underdash lever and goes to the equalizer bar on the frame crossmember. Id start chasing it from the handle to the equalizer, then chase it back to to brakes if you know the cables are good. May be as simple as just being out of adjustment.
1964 Short bed trailer
Old 07-30-2013, 01:02 PM   #3
FF SIX ONE
FF SIX ONE's Avatar
I had the same issue on mine, and all I had to do was flush out the cables with lubing spray. Although 1963c-10 has a good point , inspect the whole system.
FF SIX ONE is offline   Reply With Quote
Old 07-30-2013, 01:13 PM   #4
tr4boy
Thanks, guys, will do on both recommendations...
Old 07-30-2013, 01:15 PM   #5
1963c-10
1963c-10's Avatar
If you have to order any cables, keep in mind that there was a model change mid year 63. So there are two different ends for 63 cables....an early model cable and a late model cable.
Old 07-30-2013, 04:18 PM   #6
forestb
forestb's Avatar
check the return spring at the brackets under the trans.
forestb is offline   Reply With Quote
